Gravity at the Event Horizon of a Black Hole
In summary, an object would have to have infinite mass to maintain a constant altitude above the Event Horizon of a Black Hole.
RobertsMrtn
TL;DR Summary
The gravitational field of a Black Hole at the Event Horizon would have to be of sufficient strength to prevent light from escaping. The strength of the field would have to be the same for any Black Hole regardless of size. What would be the acceleration due to gravity at this point?
Acceleration due to gravity at the Event Horizon of a Black Hole.
Not a question that makes sense, unfortunately. What Newton would call "the acceleration due to gravity", Einstein would call "the proper acceleration required to hover at constant radius". You can't hover at the event horizon (it isn't even really a place in the ordinary sense of the word - it's an outgoing null surface) so your question is based on an invalid premise.
RobertsMrtn said:
Summary:: The gravitational field of a Black Hole at the Event Horizon would have to be of sufficient strength to prevent light from escaping. The strength of the field would have to be the same for any Black Hole regardless of size. What would be the acceleration due to gravity at this point?
To expand on what @Ibix said. If an object is falling to Earth, then it experiences no force. An object sitting on the surface of the Earth, however, experiences an upward force from the surface preventing it falling any further. The acceleration due to gravity, therefore, is the acceleration of a falling object in the reference frame of something at rest relative to the surface of the Earth. It's really the proper acceleration of the object on the surface that is being measured!
The same is true when an object falls into a black hole. It experiences no force (except so-called tidal forces). It has no intrinsic or proper acceleration. Its acceleration could be measured by an object at rest relative to the black hole. As one gets closer to the black hole, the force and proper acceleration required to remain at rest relative to the black hole increases without limit. Again, it is that acceleration that is really being measured. And, at the event horizon itself, it is impossible for an object to remain at rest on the horizon, so there is no way to measure an acceleration of an infalling object.
I would say that this is the direct answer to @RobertsMrtn’s question.
Thank you for your reply. According to my calculations, the acceleration would have to be infinite which would require an infinite mass. See my paper here. <personal theory link deleted>
More precisely, the proper acceleration required to maintain a constant altitude above the horizon increases without bound as the altitude goes to zero. Yes, this is well known.
This, however, is wrong. The above statement about the acceleration is true for any black hole of any finite mass.
RobertsMrtn said:
See my paper here.
Your paper is not peer-reviewed, and such papers are generally not considered valid references for discussion here at PF. Based on a quick read through of your paper, that policy is certainly justified in this particular case.
Likes Demystifier
Since you evidently did not start this thread to actually get an answer to your question or to understand the correct answer, this thread is closed.
Related to Gravity at the Event Horizon of a Black Hole
1. What is the event horizon of a black hole?
The event horizon of a black hole is the point of no return, where the gravitational pull is so strong that nothing, not even light, can escape.
2. How does gravity behave at the event horizon of a black hole?
At the event horizon, gravity is incredibly strong and causes extreme curvature of space-time. This means that time and space are distorted, and objects may appear to be moving in strange ways.
3. Can anything escape from the event horizon of a black hole?
No, once an object crosses the event horizon, it is trapped and cannot escape the black hole's gravitational pull.
4. How does the strength of gravity change at the event horizon?
The strength of gravity increases as you get closer to the event horizon. At the event horizon, the gravitational pull is infinite, meaning that the escape velocity is equal to the speed of light.
5. How does gravity at the event horizon affect time?
Gravity at the event horizon causes time to slow down significantly. This phenomenon, known as time dilation, is due to the extreme curvature of space-time caused by the black hole's massive gravitational pull.
