Gravity, center of planets, stars
In summary, at the center of planets and stars, the gravity from all sides cancels out, resulting in zero gravity. However, the pressure at the center is still present due to the weight of the mass above it. This pressure is equal in all directions and does not cancel out. Therefore, in the center, the pressure is high due to the equal forces of gravity from all sides.
Mr.Bomzh
90
Hello , it is said that at the center of planets and stars there is zero gravity because , assuming spherical geometry, the gravity from all sides comes together and cancels out in the middle and everything that is in close approximation to it.
Now that said I also read that the pressure at sun and possibly other stars is the greatest at the center , now gravity is the force responsible for this pressure yet it cancels out at the center due to similar forces from all sides how come that add to the greates pressure at center ? Thank you.
Welcome to PF!
Gravity and pressure are two very different things. The gravitational force ON YOU is what pulls you toward the center of the earth. But the pressure on you is the weight (gravitational force) on what is above you. So the pressure is due to the fact that most of the mass of the Earth is NOT located at its center.
When you are in the center, both halves of the planet(star) attracting each other and can crush you, but can not move you in any direction. In the center pressure is the same from any direction.
If you are not exactly in the center, in some directions mass will be greater than this in the opposite direction. Forces and pressure will not be in equilibrium and you will be pushed to the center.
Okay so every mass attracts every other mass , now in a star the force of gravity in the center cancels out as it is coming in similar strength from all sides , now as I understand the pressure arises from the fact that two masses are attracting so they exert pressure on themselves, the higher the mass the bigger the pressure , just like adding weights on a measuring device.
But as I said in the center of a star the gravity cancels out because it is coming from all sides equally , but since the gravity is coming equally from all sides the pressure too must come equally from all sides , so what are you saying that gravity cancels out but the pressure which is a result of gravity attracting mass doesn't cancel out yet squeezes with double force as one mass is pushing against other mass in the center and so from all possible directions?
Yes. It might be easier to visualize if you think in terms of just two large masses, one on each side of you. The left hand mass is pulling on right-hand mass, and the right-hand mass is pulling on the left-hand mass, so they want to move towards one another and squash whatever has the misfortune to be caught between them. That's pressure.
However, if we could somehow hold them apart so that they didn't come together to crush you... right in the middle of the open space between them the gravitational field will be zero as their pulls cancel out. A small object at that point will be attracted towards neither.
[edit: except that I didn't notice the word "double" - that part is wrong, as russ_waters points out below]
Mr.Bomzh said:
...so what are you saying that gravity cancels out but the pressure which is a result of gravity attracting mass doesn't cancel out yet squeezes with double force as one mass is pushing against other mass in the center and so from all possible directions?
No. Pressure acts in all directions, equally. If it pushes from the left at X and pushes from the right at -X, the pressure is just X, not 2X.
Related to Gravity, center of planets, stars
1. What is gravity?
Gravity is a force that exists between any two objects with mass. It is responsible for keeping planets in orbit around the sun, and objects on Earth from floating off into space. It is also what causes objects to fall towards the ground.
2. How does gravity work?
Gravity works by the mass of one object attracting the mass of another object. The larger the mass of an object, the stronger its gravitational pull. The distance between two objects also affects the strength of the gravitational force, with a greater distance resulting in a weaker force.
3. How does gravity affect the center of planets and stars?
Gravity plays a crucial role in the formation and structure of planets and stars. It causes matter to come together and form into spheres due to its pull towards the center. In stars, gravity creates enough pressure to ignite nuclear fusion, which produces the energy that keeps them shining.
4. What is the center of gravity?
The center of gravity is the point where the entire weight of an object is concentrated. It is the point around which an object's weight is evenly distributed, making it the point where an object can be balanced on a single point without tipping over.
5. Can gravity be manipulated or controlled?
Currently, there is no known way to manipulate or control gravity. However, scientists continue to study and explore potential ways to harness this force for space travel and other applications. The best we can do is utilize the laws of gravity to our advantage, such as through the use of rockets and satellites.
  • Classical Physics
  • Astronomy and Astrophysics
  • Other Physics Topics
