Gravity Deflects Light & Massless Particles: Einstein & Susskind
In summary, both Einstein and Susskind were wrong about gravity being the only force that affects particles. In fact, light and any other massless particles are also affected by gravity. This is a key test of GR against Newtonian gravity, and was demonstrated during a total eclipse of the Sun. However, the same argument applies to massless particles, meaning that these too should be subject to gravity, which they are not. Zero marks for logical reasoning, both Einstein and Susskind.
jeremyfiennes
323
In his GR youtube talk ( , starting 24:30), Susskind shows that a light photon on straight path in a stationary frame has a curved path in an accelerated frame. Concluding, as did also Einstein, that gravity deflects photons. But exactly the same argument applies to massless particles. Meaning that these too should be subject to gravity, which they are not. Zero marks for logical reasoning, both Einstein and Susskind?
Zero marks for Jeremy Fiennes, I'm afraid!
In Newton's gravity, only objects with mass are affected by gravity. In GR, as the theory goes, light and any other massless particles are affected by gravity. This is, then, a key test of GR against Newton.
The first test of this was during a total eclipse of the Sun. Light that passed close to the Sun (normally we wouldn't see this light) was indeed deflected and the stars behind the Sun appeared out of position. That was a big moment for GR in terms of its acceptance.
You are aware that photons are massless particles, right?
Likes Dale
Even this is debatable. In the limit of mass going to zero for particles in classical mechanics, acceleration remains constant.
Likes Dale
That is a little harsh. Even if you think they are wrong (which they are not), I would think that they would get a decent amount of partial credit for working through the problem so carefully.
That said, you are definitely in the wrong regarding GR, and although it is not as clear as in GR I also believe that you are in the wrong regarding Newtonian gravity.
I maintain: zero marks for both. The argument is purely geometrical. And therefore applies to anything, real or hypothetical, massful or massless, traveling in a straight line in the stationary reference frame. One must therefore conclude from it that anything, real or hypothetical, massful or massless, is subject to gravity. Which is nonsense.
Arrogant, much?
Why do you think it's nonsense? The bit about "hypothetical" is neither here nor there; if it's a hypothetical something it's not real and therefore not detectable. Thus this is an unscientific untestable claim. But everything else is affected by gravity, massive or massless. As @PeroK pointed out at length above, we've tested it.
That is correct. Anything with or without mass is subject to gravity. Not only is it not nonsense it has been experimentally demonstrated. The universe agrees with Einstein/Susskind and gives the failing marks to you (although I expect that the universe is kind and won't give you a 0).
Please be advised, this site is for learning mainstream physics, not for asserting personal theories, particularly not ones that have been experimentally contradicted.
Likes Sorcerer and PeroK
No, it isn't. Light is subject to gravity. Light bending by massive objects has been directly measured.
The OP is based on a mistaken belief about actual experimental evidence. Thread closed.
Likes PeroK
Related to Gravity Deflects Light & Massless Particles: Einstein & Susskind
1. How does gravity deflect light?
Gravity deflects light by curving the fabric of space-time. When light travels through space, it follows a straight path. However, when it reaches an area with a large mass, such as a planet, the fabric of space-time is curved, causing the light's path to curve as well. This is known as gravitational lensing.
2. What are massless particles?
Massless particles are particles that have no rest mass, meaning they travel at the speed of light. Examples of massless particles include photons (particles of light) and gluons (particles that bind quarks together).
3. Who discovered the concept of gravity deflecting light?
The concept of gravity deflecting light was first proposed by Albert Einstein in his theory of general relativity in 1915. However, it was not until 1919 that the deflection of light by the Sun was observed and confirmed during a solar eclipse expedition led by Sir Arthur Eddington.
4. How does the deflection of light by gravity support Einstein's theory of general relativity?
The deflection of light by gravity is a key prediction of Einstein's theory of general relativity. This phenomenon can only be explained by the concept of a curved space-time, which is a fundamental principle of general relativity. The successful observation and confirmation of this phenomenon during the 1919 solar eclipse was a major factor in the acceptance of Einstein's theory.
5. What is the connection between gravity deflecting light and the holographic principle?
The holographic principle, proposed by physicist Leonard Susskind, suggests that all the information about a three-dimensional volume can be encoded on its two-dimensional surface. The idea of gravity deflecting light supports this principle, as the deflection of light can be seen as a projection of the three-dimensional space onto a two-dimensional surface. This connection has led to further research and theories, such as the holographic universe theory.
  • Classical Physics
13K
  • Beyond the Standard Models
