Gravity Defying Ships Cause Time Dilation and Paradoxes?
In summary, there is currently no evidence to support the idea of any form of direct "anti-gravity", and even if such a device were possible, it would violate several physical laws.
Ghost117
50
If a ship could cancel out the effect of gravity, wouldn't it be able to pass through the event horizon of a black hole, and take a tour of the singularity, and then just report back with its observations?
Also, if a ship had the capability to cancel out the effect of gravity, wouldn't this cause time dilation according to General Relativity? So that if it completely cancels out gravity, it also cancels out time?
If it's fiction, you can do whatever you want.
At present, there is no scientific basis for any form of direct "anti-gravity", and most ideas for how that might work would violate multiple physical laws (especially conservation of energy and momentum), so you can't integrate such an idea with standard physics.
However, you can have many forms of indirect "anti-gravity" which do comply with the laws of physics, varying from the trivial (such as legs or rocket engines) to three-phase electromagnetic levitation (allowing hovering over a metal surface). If you want your fiction to be plausibly consistent with the laws of physics, anything which resists gravity without expending propellant must do so by somehow pushing or pulling against something at a distance in order to be consistent with conservation laws.
Fair enough Mr. Scott, but I have 2 follow up questions to clarify the points you raised regarding the violations of energy and momentum:
Energy: Are you saying that such a device would actually be creating energy by defying (i.e. modifying) gravity? I don't see how that would necessarily happen as a consequence of such a device... Such a device may transfer gravitational energy into another form of energy, but that would not be a violation... yes?
Momentum: Are you saying the M*V transfer due to collisions would be violated because M1 and M2 would not be operating under the same laws? If M1 is 'antigravitational' and M2 is a regular mass, then the net effect would not be an equal transfer of momentum? Again, would this be necessarily true?
Energy: If a device could allow the gravitational potential energy of an object to be increased without supplying the full corresponding amount of energy from another form, that would violate conservation of energy. Any sort of passive "gravity shield" idea generally runs into that problem. For example if you can move something over a "gravity shield" with a small amount of energy, then lift it up within the shielded zone, then move it out into normal gravity, you can then lower it back down and extract free energy. So there is no way to be "immune" to gravity; you have to supply at least the amount of energy necessary to work against it in a given context.
Momentum: If a device allows one object to be pushed in some direction (especially upwards) without causing something else to be pushed or pulled in the opposite direction by the same impulse, it violates conservation of momentum.
Likes Ghost117
Understood Mr. Scott, and thanks. I wonder though, besides these empirical contradictions you pointed out, if the logical contradictions in the OP also stand? Wouldn't such a "gravity shield" also become a "time shield", according to general relativity?
I can't say, as it's not very meaningful to assume something which clearly violates laws of physics then ask how it would behave according to the laws of physics!
Likes Vanadium 50 and Ghost117
Touche!
Please be sure that you are posting in the correct forum, and try to pretend to follow the rules. The science fiction and fantasy forum is for discussing existing books, comics, movies, etc...
Related to Gravity Defying Ships Cause Time Dilation and Paradoxes?
1. What is time dilation and how does it relate to gravity defying ships?
Time dilation is a phenomenon in which time appears to pass at different rates for objects in different gravitational fields. This is predicted by Einstein's theory of relativity and is observed in gravity defying ships because they can create their own gravitational fields that affect the passage of time.
2. How do gravity defying ships cause paradoxes?
Gravity defying ships can cause paradoxes because their ability to manipulate gravity allows them to potentially travel through time. This can lead to situations in which the ship's actions in the past have an impact on its own future, creating a paradoxical loop.
3. Is time travel possible with gravity defying ships?
Theoretically, time travel is possible with gravity defying ships. However, it would require immense amounts of energy and advanced technology that is not currently available. Additionally, the potential for paradoxes and other unforeseen consequences make it a highly debated and controversial topic.
4. Can gravity defying ships cause changes in the fabric of space-time?
Yes, gravity defying ships have the potential to cause changes in the fabric of space-time. This is because their manipulation of gravity can create ripples and distortions in the space-time continuum, which could have significant consequences for the universe.
5. How do scientists study the effects of gravity defying ships on time dilation and paradoxes?
Currently, scientists study the effects of gravity defying ships on time dilation and paradoxes through theoretical models and simulations. These models help to understand the potential consequences of manipulating gravity and the implications for time travel. However, more research and experimentation is needed to fully understand this phenomenon.
Writing: Input Wanted Captain's choices on colony ships
