Gravity Fed Farm Animal Watering System
In summary, the design has the potential to overflow if the water level in the bowl decreases, and the design may be difficult to maintain due to the accumulation of water and dirt in the rain barrel.
FarmerTodd
TL;DR Summary
Will this "design" work
I am trying to design/build a large self-filling drinking station, aka water bowl, for my goats and cow (see design attached)
. It's a takeoff of a dog's self-filling water bowl, i.e., uses gravity and vacuum to automatically refill the bowl as the water in the bowl is drank. The rain barrel is 50 gallons. The Water bowl is about 10 gallons.
What issues do you foresee with this design? I'm thinking the entire contents of the rain barrel will flow into the water bowl (overfilling it) if the water in the downspout evaporates as the vacuum will be lost.
Or what happens if the bowl is full, the barrel has water in it but is below the inlet on the downspout side, and it rains cats and dogs? Will the weight of the water in the downspout force the air out of the rain barrel and bubble out of the bowl or will the barrel not fill any further.
I read the title and thought "Wow - you can feed livestock gravity! What will they think of next!"
  • Haha
Likes FarmerTodd
This is not a good rig.
The vacuum in the pet bowl is lost incrementally as the level in the water bowl lowers. Every time it gets low enough, air pulled in from the bowl into the barrel and then the water level in the rain barrel lowers, allowing a bolus of water into the bowl. Repeat until barrel is empty. This is a "batch" process and will not work as you envisage as a continuous one.
There is a reason the bathroom toilet has a float valve...same idea and its the simplest and cheapest way to go. Barn feeds big tall tank which feeds the water trough through a float valve shutoff. The good news is a toilet tank valve costs $6 and you don't even need a feed-thru in the watering trough if you are clever.
Likes Rive and 256bits
Cows would lactate heavy cream...I apologize...
wow, great comments. That gives me a new idea. Build a gravity feeder and corner the 'heavy cream' market.
  • Haha
Likes Tom.G
Paging one of our more experienced ME/Farmers... @Rx7man :smile:
  • Haha
Likes hutchphd and Rx7man
I'm flattered!
Biggest problem I see is that a cow can drink 30 gallon a day no problem
I wouldn't try an have any vacuum system, just mount a barrel as high as reasonably possible so it's still lower than the gutter, and have a pretty generic float valve in the bowl
Second problem with your design as shown is when it rains, the barrell would have to be vented in order to fill, but venting the barrell will cause everything in it to drain out the water bowl
Likes Rive, hutchphd and berkeman
Additional problem is, that the low laid pipes will never dry out and hard to clean: all the dirt from rainwater will accumulate there.
Livestock needs fresh, clean water. Unless it is absolute necessary/unavoidable I would not feed them rainwater, especially if it's kept still for indefinite time.
Likes Rx7man
Thanks all for the feedback. Didn't expect my design to be compared to a toilet, but it sounds like that's where it belongs. Guess it's time and rethink this idea. Stay tuned and thanks again.
  • Haha
Likes 256bits and berkeman
Hey, it was a technical comparison only! :smile:
  • Haha
Likes FarmerTodd
Hey, the Thomas Crapper design is one of the most successful and widespread inventions in the world! So no sleight intended.
Seriously, if you do come up with a better way to do this, particularly one with few moving parts, please post it. I have never figured a way to do it without essentially a float valve...
Likes FarmerTodd
Your funny. Made me laugh.
Think float valve within a carburetor, used so that the gasoline doesn't all run out of the fuel tank and flood the system.
Likes hutchphd
Related to Gravity Fed Farm Animal Watering System
1. What is a gravity fed farm animal watering system?
A gravity fed farm animal watering system is a method of providing water to animals on a farm without the use of electricity or pumps. It uses the force of gravity to move water from a source, such as a well or rainwater collection tank, to a trough or other type of watering device for the animals to drink from.
2. How does a gravity fed farm animal watering system work?
The system works by using the principle of gravity to create water pressure. The water source is placed at a higher elevation than the watering device, and a pipe or hose is used to connect the two. As the water flows down the pipe due to gravity, it creates pressure that pushes the water out of the device and into the trough for the animals to drink from.
3. What are the benefits of using a gravity fed farm animal watering system?
There are several benefits to using a gravity fed system. It is cost-effective, as it does not require electricity or pumps to operate. It is also low maintenance, as there are no moving parts that can break or wear out. Additionally, it is environmentally friendly, as it does not require any energy consumption.
4. What types of animals can be watered with a gravity fed system?
A gravity fed system can be used to water a variety of farm animals, including cows, horses, sheep, goats, and pigs. It can also be used for smaller animals such as chickens, ducks, and geese. Essentially, any animal that requires access to fresh water can benefit from a gravity fed watering system.
5. Are there any limitations to using a gravity fed farm animal watering system?
While gravity fed systems have many benefits, they do have some limitations. The system relies on the force of gravity, so it may not work well in areas with uneven terrain or if the water source is not at a higher elevation than the watering device. Additionally, extreme weather conditions, such as freezing temperatures, can affect the functionality of the system.
