Gravity, heat, flooding, and centrifugal force on a tidal-locked planet
In summary, the conversation discusses a science fiction novel exploring a tidal-locked planet and its sequel. The discussion touches on a group trying to increase the planet's rotation, which would indirectly affect gravity. The Coriolis effect is also mentioned in relation to heat transfer and melting of icecaps. However, the main focus is on the effects of increased rotation on gravity and the potential consequences of this on the planet's climate.
Mark Everglade
Hi. I'm a science fiction author whose first novel Hemispheres, published through RockHill Publishing, explored a tidal-locked planet (Gliese 581g) where a group of activists increased its rotation to bring daylight cycles to both hemispheres. Now I'm writing the sequel, and there's ecological terrorist acts going on (I can explain why but it's not relevant to the physics questions).
Question 1) One group is trying to increase the planet's rotation even faster. Since centrifugal force would be stronger, would this indirectly increase the effects of gravity on the planet (gravity growing stronger as the planet spins faster)?
Question 2) One group of ecological terrorists are attempting to speed the melting of the icecaps. Since the planet is no longer tidal locked, the Coriolis effect exists now and that, in addition to daylight cycles, creates heat and heat transfer that melts the icecaps causing flooding. How would a nefarious group increase the speed of this flooding taking place?
Thanks!
Mark
The Earth's rotation decreases the effective gravity.
To add to what @PeroK posted. the centrifugal effect acts outward from the axis of rotation. And gets stronger as you move away from the axis. Thus this effective weakening is zero at the poles, and increases as you move towards the equator. But it is a small effect for something the size of the Earth rotating once every 24 hrs.
As far as Coriolis effect goes. The transfer of heat from equator to poles does not rely on it. This is done by simple convection. Air is heated at the equator, rises and moves towards the poles were it cools, sinks and then moves back towards the equator. You get air circulation of warm air moving towards the Poles in the upper atmosphere and cold air moving away from the Poles at ground level. What the Coriolis effect does is change the pattern of this circulation so that it is no longer along a straight North-South line.
Likes Mark Everglade and PeroK
That depends on what you mean with "the effects of gravity on the planet". Do you mean gravitational forces of the star acting on the planet or gravitational forces of the planet acting on something else that is located on the planet? For the second case it has already been mentioned that the gravity on the surface of the planet will be reduced at most places. It can (but don't need to) be increased on the poles (depending on the size of the core). For the first case you need to distinguish between the gravitational net force (which will be almosty unchanged) and the tidal forces (which will be increased around the aequator).
That makes sense, thanks a lot!
Related to Gravity, heat, flooding, and centrifugal force on a tidal-locked planet
What is gravity and how does it affect a tidal-locked planet?
Gravity is a force that attracts objects towards each other. On a tidal-locked planet, gravity is strongest at the center of the planet and decreases as you move towards the poles. This means that objects will experience a slightly different gravitational pull depending on their location on the planet.
How does heat play a role in a tidal-locked planet?
Heat is an important factor on a tidal-locked planet because one side of the planet is always facing the sun while the other side is always facing away. This creates extreme temperature differences between the two sides, with one side being extremely hot and the other being extremely cold.
What causes flooding on a tidal-locked planet?
Flooding on a tidal-locked planet is caused by the gravitational pull of the planet's star. As the planet orbits around its star, the side facing the star experiences a stronger gravitational pull, which can cause the oceans to bulge and create high tides. This can lead to flooding on the coastlines.
How does centrifugal force affect a tidal-locked planet?
Centrifugal force is the force that acts on an object as it rotates around a central point. On a tidal-locked planet, the side facing the star experiences a stronger centrifugal force due to its faster rotation, while the other side experiences a weaker force. This can contribute to the extreme temperature differences on the planet.
Can life exist on a tidal-locked planet?
While the extreme conditions on a tidal-locked planet may make it difficult for life to exist, it is not impossible. Some scientists believe that life could potentially exist in the narrow band of habitable zone between the hot and cold sides of the planet. However, more research is needed to determine the likelihood and conditions for life on a tidal-locked planet.
  • Astronomy and Astrophysics
  • Science Fiction and Fantasy Media
