Gravity of a Rotating Cylindrical Space Station: Confirmation Needed
In summary: Both of these methods take into account the conservation of angular momentum and the effects of the change in mass on the angular velocity of the space station. Overall, your approach and answers are accurate.
99wattr89
A cylindrical space station of radius r with thin walls and mass M rotates at angular velocity ω such that the apparent gravity on the inner surface of the cylinder is equal to g.
1) Radial spokes of negligible mass connect the cylinder to the centre of motion. An astronaut of mass m climbs a spoke to the centre. What is the fractional change in apparent gravity on the surface of the cylinder?
2) If the astronaut climbs halfway up a spoke and let's go, how far form the base of the spoke will he hit the cylinder? Assume the astronaut is point like.
Solution:
1) For the first part I got that the ratio of apparent gravity before and after will be (1 - m/M)2, because angular momentum is invariant but the space station can change angular velocity, so Mrv1 = (M-m)rv2
This is a little confusing though, because if the station is effectively losing mass m, so the new mass is M-m, then the angular velocity should have to go up so that angular momentum stays the same! Why doesn't that happen? Shouldn't the effective gravity also increase as a result of the increased angular velocity?
2) The astronaut should fly off tangentially, and had to cover a distance (√3)r/2 to reach the edge of the cylinder, and he's traveling at ωr/2, so he should arrive √3/ω seconds later, right? Should the spoke stop turning he would arrive Pi/3 radians ahead of spoke.
And in that time, the spoke turns through ωt radians, which gives √3 radians.
So the angle subtending the arc between him and the spoke should be (Pi/3 - √3) radians, placing him (Pi/3 - √3)r away from the foot of the spoke.
Can anyone confirm or deny that these methods and answers are accurate? They both feel wrong to me.
Thank you for your help.
Yes, your solutions and methods are correct. The answer to the first part is indeed (1 - m/M)2 and the second part is also correct with the answer being (π/3 - √3)r away from the foot of the spoke.
Related to Gravity of a Rotating Cylindrical Space Station: Confirmation Needed
What is a rotating cylindrical space station?
A rotating cylindrical space station is a structure in outer space that is designed to simulate the effects of gravity by rotating at a constant speed. It is typically cylindrical in shape and can be used for various purposes such as research, living quarters, or transportation.
How does the rotation of a cylindrical space station create gravity?
The rotation of a cylindrical space station creates a centrifugal force, which acts in the opposite direction of the rotation and simulates the effects of gravity. This force causes objects and people inside the station to feel as though they are being pulled towards the outer edge of the rotating cylinder.
What factors affect the amount of gravity on a rotating cylindrical space station?
The amount of gravity on a rotating cylindrical space station is affected by several factors, including the radius of the cylinder, the speed of rotation, and the mass of the station. A larger radius, faster rotation, and greater mass will result in a stronger simulated gravity.
What happens if the rotation speed of a cylindrical space station is too low or too high?
If the rotation speed of a cylindrical space station is too low, the centrifugal force will not be strong enough to simulate gravity, and objects and people inside the station will experience a feeling of weightlessness. If the rotation speed is too high, the centrifugal force will be too strong, causing objects and people to feel heavier than they would on Earth.
How can the gravity of a rotating cylindrical space station be confirmed?
The gravity of a rotating cylindrical space station can be confirmed through various methods such as measuring the acceleration of objects inside the station, observing the curvature of water surfaces, and conducting experiments with pendulums. These methods can help determine if the simulated gravity is equivalent to the gravity on Earth.
