Gravity on the Moon vs. on the spinning Earth
In summary: No. It has gravity because it has mass - anything with mass has gravity, although it's tiny for anything smaller than an asteroid. The spin just gives you a centrifugal force (same thing that presses you against the car door when you go round a corner) that modifies your weight slightly at the equator compared to the poles.
jon2
TL;DR Summary
moon vs earth gravity
"If the Earth were not spinning, you would be heavier as you would feel the full force of gravity."so how does this apply to the moon? the moon does not rotate and therefore you would experience the full force of gravity as stated above,yes,,yet the appolo missions film footage showed weightlessness ,the moon does not rotate so there should be full gravity experience..yes?no floating as the astronauts appear to be experiencing,,am i missing something here? thanks..j
  • Skeptical
Likes davenn
The Earth has 81 times more mass than the Moon, so what you see in Apollo is not "weightlessness", [EDIT] it is just one-eightieth of the weight on Earth. That looks like weightlessness but it is not.
[EDIT] @Ibix points out below that the smaller diameter of the Moon makes the person's weight on the surface 1/6 of the weight on Earth, not 1/81.
In addition to what @FactChecker said, the moon does rotate. It rotates about once per month.
Likes vanhees71, SammyS and Vanadium 50
Yes it does - how else would it keep one face always towards the Earth?
Not when they're landed on the moon. They have reduced weight but not zero weight.
Remember that the moon is a lot smaller than Earth too. Surface gravity is about a sixth of a g, not an eightieth
Likes vanhees71, Orodruin, berkeman and 1 other person
Good point. I'm surprised at the huge difference it makes, but I was thinking that 1/81 seemed way too small. 1/6 is a lot more believable.
Likes berkeman
##1/r^2##, remember, and the moon is about a quarter the radius of the Earth.
Likes FactChecker
...and finally, remember that the rotation of the Earth makes only a tiny difference to your weight - you'd weigh about 0.3% more at the poles compared to the equator, if my back of the envelope calculation is correct. That's less than the weight difference from eating lunch. If the Earth didn't spin you'd never notice the difference in your weight compared to reality.
Hal Clements' "Mission of Gravity" is an excellent hard scifi exploration of a world with a serious rotation rate, if you ever come across it (the slide rules date it a bit...).
Likes vanhees71
So in turn the moon has gravity because of this slight spin?
No. The moon would have gravity even if it didn't spin.
Likes vanhees71
No, the spin of the moon is so slight that it is essentially irrelevant
Likes vanhees71
Likes vanhees71
FAQ: Gravity on the Moon vs. on the spinning Earth
How does gravity on the Moon compare to gravity on Earth?
Gravity on the Moon is approximately one-sixth of the gravity on Earth. This means that an object that weighs 100 pounds on Earth would only weigh about 16.6 pounds on the Moon.
Why is gravity on the Moon weaker than on Earth?
The strength of gravity depends on the mass and size of an object. The Moon is much smaller and less massive than Earth, so it has a weaker gravitational pull.
Does the Moon's rotation affect gravity?
No, the Moon's rotation does not affect gravity. Gravity is determined by the mass and size of an object, not its rotation.
How does the Earth's rotation affect gravity?
The Earth's rotation does not affect the strength of gravity, but it does have an effect on the direction of gravity. The Earth's rotation causes the force of gravity to be slightly stronger at the poles and slightly weaker at the equator.
Can humans jump higher on the Moon due to the weaker gravity?
Yes, humans can jump higher on the Moon due to the weaker gravity. The lower gravity means that there is less force pulling us back down to the surface, allowing us to jump higher and stay in the air longer.
