Does Organic Matter Experience Gravity on the Moon?
In summary, the question of whether organic matter experiences gravity on the Moon explores the fundamental principles of physics as they apply to different celestial bodies. Organic matter, like all matter, is subject to gravitational forces, which means it does experience gravity on the Moon, albeit at a weaker level than on Earth due to the Moon's lower mass and gravitational pull. This has implications for biological processes and potential life-supporting systems in lunar environments.
samcan
This may already have been answered but I can’t find it.
If organic matter is disturbed, exp. on the moon, does the matter experience a gravitational pull?
Likes berkeman
Have you done your intro stuff? Read the pf rules? You need to do all that before posting a question.
Everything experiences gravity. Organic matter is not an exception
Likes Vanadium 50, russ_watters and pinball1970
Welcome to PF.
Can you give an example of which organic matter on the Moon you are thinking of? And in which way is it "disturbed"? Thanks.
Dale has replied so I assume you have posted your intro.
"Organic chemistry" is Carbon chemistry simply put. More specifically, carbon - carbon and carbon- hydrogen bond chemistry but the pf expert @Borek would give the best definition.
Welcome to PF.
I watched film earlier of the flag being planted on the first moon mission. The astronauts disturbed the ground material, while they were visibly experiencing weightlessness the matter they disturbed was not. The material acted like sand on earth, no weightlessness noted. So I wondered why. Thanks
  • Skeptical
Likes PeroK, russ_watters, weirdoguy and 1 other person
The force of the Moon's gravity on its surface is about 1/6 of the force of gravity on the surface of the Earth. Have you seen the videos of the lunar astronauts riding around in the lunar rover? That gives you a better idea of what the lunar "soil" material does when it is flung up.
Likes pinball1970 and samcan
The astronauts were not weightless, but they did weigh only about one-sixth of what they would on earth. That’s a big enough difference to make their movements look strange. The rock dust they disturbed would have also have weighed one-sixth what it would have weighed on earth.
Likes samcan
Why do you think so?
Thank you, my opinion was that the material didn’t appear to “fall” with even one-sixth weight, but rather more like sand on a beach, I found it odd.
I apologize if I’ve overstepped in asking this question, it just was something I couldn’t reconcile.
  • Skeptical
Likes PeroK
Thank you, I still can’t reconcile the movement of the material, maybe it’s just me!
Remember that there is no atmosphere on the Moon, so that will affect the movement of the soil particles as well.
Likes samcan
One other issue - the moon regolith is not "organic matter". It's a fine powder of rock. It is nothing like earth soil. It is also quite chemically different from sand - there is little quartz on the moon.
Likes russ_watters
My mother always told me that the Moon was made out of cheese. That is organic material, but when the sunshine falls on it, it does not melt and run down the face like here on Earth, so organic material is not affected by gravity on the Moon.
  • Haha
Likes SammyS and berkeman
There are just two relevant differences between earth and the moon for these situations: 1/6 g acceleration and no atmosphere.
Astronauts have reflexes trained in 1 g, so they appear clumsy. They are clearly not weightless, but also clearly they are not moving normally.
Lunar regolith doesn’t have any reflexes. So it behaves more or less normally. There is no atmosphere, so it simply follows normal projectile motion. Gravity is 1/6 g, but that is hard to tell from low frame rate video. But that is it, there is no clumsiness or other cues for the regolith.
Likes DrClaude, Doc Al and Vanadium 50
With that good summary by @Dale (and a little humor from @Baluncore ) this thread is now closed. :smile:
Likes DrClaude, Bystander and phinds
10K
