Gravity & Photon Trajectory: Is Wavelength a Factor?
In summary, the question of whether two photons of different energies, with wavelengths of 900nm and 200nm, will be refracted at different angles when passing near a massive object can be answered with a "no." This is because in general relativity, gravity is not a force but a property of spacetime geometry, and all objects, including photons, follow the same geodesic path regardless of their energy. This has been tested experimentally and no differences have been found in the deflection of different frequency signals by the sun.
chimera27
This seems like an intuitive question, but I've seen some rather contradictory answers on it and am not sure what to think. What I'm curious about is if two photons, A and B, with wavelengths 900nm and 200nm respectively, both start from the same point on the same trajectory passing near a massive object, will photon A be refracted at a larger angle than B? I would think yes, but I'm not sure, as I've seen both remarks that say the velocity (in this case 'c') alone is factored, and remarks that it would indeed affect it. Both answers raise interesting questions, and I'm not sure which better describes the situation. Any thoughts?
You should not use the word "refracted" in this connection, because it invites the (incorrect) comparison with the refraction of light in a material medium that you are being tempted to make. Unfortunately there isn't a fancy word for the bending of light by gravity; it's usually just called "the bending of light by gravity".
There are at least two ways to understand why the answer to your question is "no"--i.e., why photons of different energies are bent the same by gravity. The first is by analogy with objects with nonzero rest mass; all such objects have their trajectories "bent" the same by gravity. If you shoot two rocks past the Earth, one more massive than the other, with the same initial positions and velocities, they will both follow identical trajectories. By analogy, the same should be true for two photons of different energies which are shot with the same initial positions and velocities (the velocities have to be the same in this case because they're both photons).
The second way is to recognize that, in GR, gravity is not a force; it's spacetime geometry. The "bending" of the paths of objects is a property of the geometry of spacetime, not a property of the objects. The geometry of spacetime is the same for all objects, photons included.
Likes chimera27
To amplify on this for the OP, the track of a photon through spacetime is a geodesic, which in a curved space is the equivalent of a straight line. A geodesic is as straight as possible. (The equivalent on a sphere would be an arc of a great circle.) Two photons with different energies and otherwise identical initial conditions will both go "straight," i.e., both will follow the same geodesic.
Likes vanhees71
Basically, the answer is no - the light will travel the same path (called a null geodesic) regardless of energy or frequency. Energy and frequency are related by quantum theory by the relation ##E = h \nu##, E being energy and ##\nu## being frequency. Technically, "photons" are outside the scope of GR, but if one replace "photon" with "weak light pulse" one gets the answer above, that the deflection is independent of frequency. So gravitational lenses don't show any chromatic aberration, for instance.
The fine-print exception to the above is that if you had gravitationally significant amounts of energy in the light (atypical, and probably not what you had in mind when you asked about "photons"), the approximations used to get the above result would be invalid, and the path would depend on the total energy in the light pulse (though it wouldn't depend directly on the frequency even so, but it might depend on the total energy, which in quantum terms would be the number of photons multiplied by the energy per photon. But see the remarks about GR being a classical theory.)
Likes vanhees71
Thanks, that's what I thought. just wanted to confirm since I had heard a few contrary remarks when researching it. Also, my use of 'refracted' was simply keeping in terms of the gravitational 'lensing' analogy, and was purely a semantical error, not a genuine misunderstanding xD
IIRC this has also been tested experimentally by comparing the deflection of radio and/or light signals with different frequencies by the sun. No differences (dispersion) has been found.
Likes vanhees71
FAQ: Gravity & Photon Trajectory: Is Wavelength a Factor?
What is gravity?
Gravity is the force that attracts objects towards each other. It is a fundamental force of nature that is responsible for keeping the planets in orbit around the sun and for keeping objects on Earth from floating off into space.
How does gravity affect the trajectory of photons?
Gravity affects the trajectory of photons by bending their path as they pass through a gravitational field. This is known as gravitational lensing and it occurs because photons have energy and therefore mass, which is affected by gravity.
Is wavelength a factor in the trajectory of photons?
Yes, wavelength is a factor in the trajectory of photons. The wavelength of a photon determines its energy and therefore its mass. This mass is affected by gravity, causing the photon's trajectory to be bent.
How does the wavelength of a photon affect its path in a gravitational field?
The wavelength of a photon affects its path in a gravitational field because it determines the amount of energy and mass the photon has. The higher the energy and mass, the more it will be affected by gravity and the more its path will be bent.
Can the wavelength of a photon be affected by gravity?
No, the wavelength of a photon cannot be affected by gravity. However, its path can be bent due to the mass and energy of the photon being affected by gravity.
