- 30
I've been looking around in various physics books and websites - talking to some people too - and cannot find anything on gravity.
I don't mean the inverse sqaure law [ F = G m1m2/r2 ] or
gravity's constant [ G = 6.67 * 10^11 m3 Kg s-1 ] but more to the point how the particles ( on the quantum level ) exist. How is it thougth today - from Theory of relativity & Newtons Law of Universal gravitation or any other theories to how gravity interacts and behaves in the terms of particles?
I've heard about it being a boson with a spin of 2 and so forth, but as the photon requires a source ( such as a charged particle e-, p+ ) so should classically the gravity require a fermion source to which the particle is a interaction field boson carrying the gravity force?
Is this force thought to be a particle that is emmited directly from mass?
_________________________________________________________________
On a separate note - it seems that most hypothesis's formed for gravity somehow relied on EM (ElectroMagnetism) in some way.
How does a system (a proton and electron, - so hydrogen) keep the conservation of energy is terms of emmiting its charge.
1/.
If a electron where to travel through space, then I am assuming that it will emmit photons (quantized they are the EM charge, 0 mass) and after a certain time (a great deal of time) the electron would eventually disintegrate into nothing and only photons would be left scattered. I'm assuming that the charged particle does expend photons as the charge and after a certain amount of time the energy is used - that it can't expend a charge forever. But if you were to count up all of the scattered photons then the original energy would be accounted for -i.e " conservation laws '' - in an isolated system energy is conserved.
2/.
We have two main interaction fields inside EM in this instance
,repulsion and attraction. A charged particle will expend a charge (force carrying particle - photon) onto another charged particle and this will cause a repulsion - assuming that both particles are of the same charge - i.e proton ++ proton or electron -- electron. But these photons, they have no charge so how do the EM fields differ between positive and negative? Furthermore is there a certain radius (in fermi say 10^-10, or 10^-15 or something) where a dense aggregated amount of charge exists, say a "electrostatic barrier" where another charged particle of the same charge would find it extremely hard to get into. And if it has breached this barrier than it may interact on a baryon-baryon level using the strong interaction?
What I am basically asking is does the barrier of one particle at a certain distance away repel the charged particle (assuming same charges) or do the barriers of each particle repel each other from the surface on each EM field?
So how does a electron and proton (inside a hydrogen molecule) exist?
How is the charge conserved - energy conserved. Is there an absorbtion of photon? Is a + particle attracted to the photons of a - particle and absorbs them, then somehow interpolates the charge and expends its respective charge - how does this conservation work in a atomic system for such a long amount of time? How are particles attracted to each other yet they stay at a certain distance away in orbit?
This further leads me to believe somehow that gravity fundamentally does not work as explained or theorized.
Say if a 2 lead balls of the same size and mass were put into a empty region of space and put at rest at 100m from each other then theoratically it is believed by everything we are told, i.e Newton once said - through the Universal Law of Gravitation, that every particle attracts every other particle in the universe. So these two objects should attract one another - assuming that they are stationary and no external force is applied. Both objects should gain acceleration towards each other. Now this is where the problem arises. The force of attraction is much more complex then repulsion. Repulsion only requires the expeniture of force carrying particles to stike another body. With attraction however classically described through electromagnetism - both particles must have the same but opposite force (i.e the proton has 1.6*10^-19C and the electron has -1.6*10-19C). So you need equal but opposite gravity in this case for both lead balls. Now if you were to discriminate against particles, then you should classically be able to arrange each elementary particle - whether it be a fermion or a boson into sepertate list's - either having positive or negative gravity( just as they have spins, mass and charge ). That way the same repel and opposites attract.
Now because both balls are lead, metal made of cations in a sea of electrons the particles are exactly the same and the balls should not be theoratically able to attract on each other. Furthermore - this brings me to the supposition that space not mass is where gravity originates from. By space I mean empty 3-Dimensional geometric space with the inclusion of time.
So instead of mass/energy expending gravity and the system is distorted as particles run into this gravity, that gravity itself is a product of space and the inclusion of mass into space distrorts the very facric of geometry. The gravity pertains to the space. Furthermore I am compelled to say that gravity emmits from a gravity fermion source, and the gravity particle which are the interaction field bosons carry the gravity force. So through this hypothesis one assumes the fermion to be the graviton, and the bosons to be the gravity particles. (analogous to electron and photons)
1/.
2/.
