- #36
Russell E
- 97
- 3
1bobwhite said:Nearly all of the responses to this experiment have apparently been made from theory only, and with an irritation that an attempt is being made at possibly showing that the GR theory may be in need of reconsideration.
That doesn't describe any of the response that I've seen. I think you've mis-read and/or mis-interpreted the responses.
1bobwhite said:Well my "agenda" is to try to establish a repeatable demonstration of the real world forces that can be compared to the theoretical assertions.
You've missed the points that have been made. First, the thing you say you are trying to demonstrate was already demonstrated over 200 years ago by Laplace, when he showed that the stability of the planetary orbits imply virtually no aberration in the force of gravity. This is a well-known fact. Second, the results of this demonstration have already been "compared to the theoretical assertions". In particular, the absence of discernable aberration is consistent with the only empirically viable theories of gravity that we possess, in which the propagation speed if c. There is no known empirically viable theory of gravity in which the propagation speed differs from c, which is one of the things that makes it so difficult and contentious when trying to design experiments to test for the speed being different from c. But for the purposes of this thread, all of that is irrelevant, because the one thing we know for sure is that the proposal you are discussing, to infer the speed of propagation from simple force aberration, is untenable.
1bobwhite said:Whether the results confirm or refute the supposed facts of these theories will have to be determined after the data is in.
Again, you've missed the point. The data you're discussing is already "in". It's been "in" for over 200 years. And the theoretical implications of this particular bit of data are well understood (by physicists).
1bobwhite said:Many of my references and reasons for making the attempt at the experiment are contained in the following article: http://iopscience.iop.org/0004-637X/590/2/683/fulltext
All the excerpts you quoted from that reference simply confirm what people here have been telling you. None of those proposed observations are of the kind that you are discussing. You are talking about measuring the direction of the force, i.e., simple force aberration, which is already well known. There is no appreciable aberration in any relativistic force, and this applies to electromagnetism as well as gravity and the strong and weak nuclear forces.
1bobwhite said:Excerpt: 1 A similar conclusion was reached by Carlip (2000) in the context of binary motion, in esponse to a proposed bound on the speed of gravity by Van Flandern (1998).
A foot note to show that Van Flandern's proposal was being considered with recognition for his work, that has been referred to here as "crackpot".
Again, the excerpt you quoted simply confirms what people have been telling you. Van Flandern was indeed a crackpot, as can be inferred from the excerpt that you quoted. He made the same elementary mistake that you are making, i.e., he supposed that the absence of aberration in the force implies a Laplacian lower bound on the propagation speed. The is a well known fallacy for over a century, and was even described as a fallacy in the paper that Van Flandern cited as his source.
1bobwhite said:All I have heard on this forum so far is the negatives of how wrong I am in my thinking and how impossible and worthless the experiment is.
Your thinking IS wrong. As to the experiment, it isn't so much that it's worthless or impossible, it's just redundant. The absence of gravitational aberration has been a well established empirical fact for centuries.
1bobwhite said:Not one single post has been made for how to design a workable experiment or how to improve a procedure to make extremely sensitive measurements.
That's simply not true. Many people have pointed out the most sensitive way of determining the aberration of the gravitational force, namely, by observing the orbital stability of the planets, from which we can say that there is no discernable (first order) aberration in the force of gravity. And of course this is entirely consistent with general relativity and with a propagation speed of c.
1bobwhite said:Why are there so few amateurs taking up this challenge?
I think you underestimate the intelligence of most amateurs, who are fully capable of grasping that the absence of aberration in the force of gravity is (1) perfectly well established by observation, and (2) perfectly consistent with general relativity and a propagation speed of c.
