Gravity, Time Dilation & Black Holes: Q&A
In summary, orbiting a black hole for a year would require being close to its event horizon, at approximately 1.5 times its Schwarzschild radius, to experience a time dilation ratio of 1 to 10,000. However, this would result in an unstable free-fall orbit with the closest stable orbit being at 3 times the Schwarzschild radius.
mileymo
I'm wondering if a ship orbited a black hole for a year, how large would the black hole be for it to equal 10,000 years on earth?
It would depend not only on the mass of the BH, but also on the distance at which the ship is orbiting.
The closer it is to the event horizon the more noticeable would be the time dilation for a distant observer.
Janus said:
orbiting at ~1.500000015 times its Schwarzschild radius
It's worth noting that this will be an unstable free-fall orbit; any small perturbation will either send you into the hole, or send you out to infinity. The closest stable free-fall orbit is at 3 times the Schwarzschild radius, where the time dilation factor is much smaller, only ##\sqrt{2}##.
Thanks very much!
Related to Gravity, Time Dilation & Black Holes: Q&A
1. What is gravity?
Gravity is a fundamental force of nature that describes the attraction between two objects with mass. It is responsible for keeping objects, such as planets, in orbit around a larger body, such as a star.
2. What is time dilation?
Time dilation is a phenomenon in which time appears to pass at different rates for objects in different gravitational fields or moving at different speeds. It is a result of the curvature of spacetime, as described by Einstein's theory of general relativity.
3. How are gravity and time dilation related?
Gravity and time dilation are closely related because gravity is a result of the curvature of spacetime, and time dilation is a consequence of this curvature. Objects with more mass, such as planets and black holes, have a stronger gravitational pull and therefore experience more extreme time dilation effects.
4. What is a black hole?
A black hole is a region of spacetime where the gravitational pull is so strong that nothing, including light, can escape its grasp. It is formed when a massive star dies and collapses under its own gravity, creating a singularity, a point of infinite density and zero volume.
5. Can anything escape from a black hole?
No, nothing can escape from a black hole, not even light. The intense gravitational pull of a black hole is so strong that it traps everything within its event horizon, the point of no return. However, some theoretical models suggest that particles can escape through quantum effects, but this has yet to be proven.
