Gravity: What Moves a Stationary Body?
In summary, the force of gravity only seems to apply if the body is moving. What moves it if it starts off stationary and then falls?
woolyhead77
TL;DR Summary
The path taken by a body in free fall is a geodesic. But if the body is initially stationary it falls when released. Why?
We are told gravity is a curvature in spacetime but the force of gravity only seems to apply if the body is moving. What moves it if it starts off stationary and then falls?
They are geodesics in spacetime. You can't not be moving forwards in time.
You are probably being misled by pictures showing space around Earth as curved. In such diagrams, all the interesting stuff happens in the time direction - which isn't shown!
Likes bhobba and FactChecker
Likes Spinnor, timmdeeg and Ibix
woolyhead77 said:
Summary:: The path taken by a body in free fall is a geodesic. But if the body is initially stationary it falls when released. Why?
It was only stationary because a force was keeping it from following the geodesic (which is why it had to be released) and when the force is released, it moves along the geodesic.
Likes sysprog
In this context, "stationary" means that the object is following a non-geodesic path through spacetime parallel to our own, and therefore is not moving relative to us.
(Phinds knows this of course - this comment is for OP as they read the replies)
Likes sysprog and phinds
I get it. Thanks.
Yes I see. Thank you.
Now that I've thought about your replies it seems to me you haven't really answered my question because although time is a part of spacetime it doesn't curve around a mass like space does, so far as I know. And although the mass moves through time it is presumably not moving along one of the geodesics of space. So what pulls it towards the large mass (earth)? You can't have it both ways: (i) there is no separate space, only spacetime (ii) the geodesic is space curving, not time. Please tell me where this is wrong.
Yes, it does. The video @A.T. posted is describing curvature of time. More precisely, it's describing effects of spacetime curvature that show up as effects on time, not space.
No, the mass is moving on a geodesic of spacetime. Its path in space is, except in certain special cases like purely radial motion, not a geodesic in space.
You need to stop thinking in terms of separate "time" and "space" and start thinking in terms of spacetime.
Likes bhobba and sysprog
It most certainly does! Newton's theory of gravity is an approximation to general relativity in the case where curvature in the time direction is the only important curvature (wincing slightly as I write that - more precisely ##G^{tt}=0## is the only equation with significant terms). So near Earth, where non-Newtonian behaviour of gravity is incredibly difficult to detect, spatial curvature is more or less irrelevant. Pretty diagrams of such curvature are impossible to draw, however, so all you see outside serious textbooks is the unimportant spatial curvature, seriously exaggerated.
Masses follow geodesics in spacetime. The spatial projection of those paths may or may not be geodesics of the spatial slices (I don't know), but it isn't important for anything.
Likes dextercioby and sysprog
I'll think about it. Thanks for now.
As I said, in all but a few special cases (such as purely radial motion), the spatial projections will not be geodesics of the spatial slices.
woolyhead77 said:
...not moving along one of the geodesics of space...
Correct, the free falling path doesn't have to be a geodesics of space. The spatial path is a projection of the space-time geodesic onto the spatial dimensions.
Sorry - didn't see your post. I suppose it's kind of obvious though. If we're arguing that space is more or less flat near Earth then circular orbits are manifestly not geodesics of "nearly" flat space.
I am now thinking in terms of spacetime and my comments are now:- Let the smaller masses' projections of spacetime geodesics on to space be called space paths for simplicity in my question and its likewise projection of spacetime geodesics on to time and which I will call time pathways for simplicity in this question, (I) are they the identical? (ii) since the stationary mass I originally proposed is moving in time, as Ibix said, and moving along a projected time geodesic, it is presumably not accelerating in time and so there is no force of gravity acting on it. (iii) since this mass crosses no projected space geodesic it is not accelerating in space so there is no force of gravity acting on it. (iv) why does it fall? (v) where are the fallacies in questions (i) to (iv)? I don't see why I must stop thinking in terms of space and time as separate identities from now on. To do so would prevent me asking more fundamental questions about gravity.
"Space" depends on your choice of coordinates so what you are doing here is taking you away from the actual physics, not towards it. The actual physics is contained in invariants, quantities that are independent of your choice of coordinates.
There is no such thing; you can't project a curve in spacetime "onto time".
Because they're not separate entities in relativity. The entity is spacetime; "space" and "time" depend on your choice of coordinates. If you continue to insist on thinking of them as separate, you will simply not be able to understand the things you are trying to understand.
Likes vanhees71 and sysprog
On the contrary. Not to do so would prevent you from understanding anything fundamental avout the description of gravity in terms of general relativity.
The fundamental truth is that, at least in relativity, spacetime is one entity, and you can't generally split them up in any meaningful way. There's always some freedom to choose how you define space and time, and if there's freedom for you personally to choose then there can't be any physical significance to the choice. Of course, there are often obvious ways to do the split. And there's always an obvious way for a person to do it for spacetime near themselves - it's just not possible to unambiguously extend that to everything.
General relativity is our most fundamental theory of gravity so far. If you ask questions about gravity, people will answer in terms of spacetime. You may not like those terms, but you will need to accept them to be able to communicate about gravity.
It makes sense to talk of the projection of geodesics onto space, since space is a 3d slice through spacetime. It's like the shadow of a curved rod on the ground. It doesn't make sense to talk about the projection of the geodesic onto time since that's a 1d slice of spacetime. It's like asking what shape the shadow of the curved rod is on a hair hanging vertically. For a start, you need to specify where the hair is, and the answer is going to be pretty unexciting (it'll look like a bit of hair) once you've done it.
Technically, this is only true in stationary spacetimes. If your spacetime is not stationary then ”space” itself will look different for different ”times”.
Likes bhobba, dextercioby, vanhees71 and 2 others
woolyhead77 said:
... since this mass crosses no projected space geodesic it is not accelerating in space ...
What does "accelerating in space" mean? The free faller worldline is a geodesic in space-time. If you project it onto space, you get a path that might be curved or straight (radial fall). It has coordiante acceleration (dx/dt != 0) but no proper acceleration (what an accelerometer measures).
OK I give in. I know you are all right of course. What I also feel is that because people have experienced space and time as separate things since time immemorial it is rather a lot for us to swallow the idea that they are part of spacetime, a thing we had never heard of when I was young. But I'm interested in finding out where this spacetime concept came from and the reasons why it was recognised/invented. I think it was Einstein's idea, based on his mathematics and his desire to understand how God made the universe, so instead of simply quoting the results of his thinking could someone please relate how his reasoning worked: why/how did he invent the spacetime idea?
He didn't. Einstein's 1905 paper justified and explained the Lorentz transforms as the relationship between my space and time coordinates and those of another inertial frame, rather than a mathematical patch to Maxwell's equations as was previously assumed. It was Minkowski who pointed out in 1908 that these transforms could be interpreted as meaning that space and time were part of one 4d structure, christened spacetime.
Einstein then took that idea and ran with it, realising that you could model gravity as curved spacetime. But he did not invent the notion.
Likes Dale
woolyhead77 said:
What I also feel is that because people have experienced space and time as separate things since time immemorial ...
And they believed for a VERY long time that the Earth was the center of everything, and they had never heard of quarks, and I could go on and on... Get used to it.
phinds said:
Get used to it.
Don't think, @woolyhead77, that this stuff came naturally to anyone. The maths of special relativity (published 1905) is implicit in Maxwell's equations (published around 1862). It took forty years to puzzle out, and another ten to expand special relativity to general relativity. And there are still arguments about how best to teach it and it can take years to get your head around it.
But the evidence is compelling. Without GR we can't explain the behaviour of light near masses, nor the exact precession of Mercury' orbit, nor the behaviour of clocks at different heights, nor the redshift of distant galaxies... "Get used to it" is a fairly blunt way of putting it, but an awful lot of "common sense" knowledge about the universe is hilariously wrong outside the limited range of our everyday experience.
Likes bhobba, vanhees71 and phinds
quote: "these transforms could be interpreted as meaning that space and time were part of one 4d structure, christened spacetime." Would anyone care to expand on this a bit, please?
It's difficult without knowing how much maths you know. Riemann and others had done a lot of work on the geometry of smooth spaces - more general spaces than the Euclidean plane geometry you probably studied in school. Minkowski apparently recognised that the Lorentz transforms were the same maths that represents "rotations" (typically called boosts, but they are the hyperbolic analogue of rotations) in a type of space now named after him. I don't know if that space was known before Minkowski or if it was his own personal invention. Either way, it's a four dimensional "space" with one dimension that's different from the other three and whose behaviour under boosts matches Einstein's maths. That's spacetime.
Note that I believe that other interpretations of the maths are possible. But using geometrical language opens up the whole toolkit of Riemann's differential geometry, so everyone uses that.
Likes Klystron and phinds
What I now think I know is that as the Earth moves through spacetime it bends spacetime as it travels along. When Earth moves along a bit it leaves the bent piece of spacetime behind and it straightens itself out as the Earth bends a new piece as it were. It's a dynamic process. So in fact my mass cannot be stationary relative to spacetime. It is impossible. I must admit I had a different image of how it happens all in my mind until the penny dropped. I imagined that the particular piece of spacetime which the Earth bent actually stayed with the earth. Of course this image was wrong, I see that now. And another mass that is stationary with respect to the centre of the Earth but is in the flow of the Earth's bent spacetime must cut the geodesics and is therefore accelerating and therefore feels a force, the one we call gravity. Have I got this right?
  • Skeptical
Likes PeroK
Thank you IBIX. I do know a bit of maths as it happens so now I have a link which I can follow up.
I've thought about it now and asked several more questions and every time I've received helpful replies. I want to thank everyone for their help (and forbearance against my stupidity). You have all been great.
Thank you. I appreciate your kindness in the way you answer. And I am getting used to the idea of spacetime after receiving a lot of help from everyone.
  • #31
Note that in curved spacetime and the theory of GR there are no preferred reference frames. It's not really possible to say that this view of spacetime with the Earth moving is correct and a different view with the Earth at a fixed point in space is not. In fact, if you study the spacetime around a large object like the Sun or the Earth, it's usual to look at this as a static scenario. I.e. you can describe the spacetime in such a way that it does not change with your time coordinate.
The Earth itself is following a geodesic as it orbits the Sun, which can be seen as a static field. If you include the Earth (and other planets) in your model as objects large enough to affect the spacetime in the Solar system, then you get a dynamic solution, which changes as the planets change their positions relative to the Sun and each other. But, there is nothing absolute about this view.
For an object on the surface of the Earth, a simple view is that the geodesic is towards the centre of the Earth, and it's the force from the Earth's surface that prevents the object following this. This isn't the force we call gravity, which would be a force towards the centre of the Earth. The force we call gravity is the fictitious force that counteracts this upward force. In Newtonian physics we must have this force of gravity so that forces are balanced.
In GR, the object has a real upwards force and a proper acceleration but owing to the curvature of spacetime the surface of the Earth at that point represents an accelerating reference frame. The net result is that the object remains on the surface.
If you look at that object and ask "if that object has an upwards force, why isn't it accelerating relative to me?", then the answer is that you too have the same proper acceleration.
If you look at an object falling "under gravity" and ask "why is it accelerating, when it has no force on it?", then the answer again is because you have proper acceleration.
  • #32
This is not really a correct description, although it has some heuristic value.
The Earth does not "move through spacetime". In spacetime, the "earth" is a "world tube"--a tube that occupies a certain portion of spacetime. Spacetime is curved near this world tube because, as you say, the Earth causes spacetime curvature--or, to put it another way, there is stress-energy present inside this world tube, which causes the spacetime in and near it to be curved. But this world tube does not "move"--it simply is.. It is a geometric object, a tube, lying within a larger geometric object, all of 4-d spacetime. The Earth, or more precisely its stress-energy, is "there" in every part of that world tube. It does not "move" from one part to another.
At the center of the Earth's world tube is one particular worldline, the worldline of its center of mass. This worldline is a geodesic; if we take a larger scale view we see that it is a geodesic in the curved spacetime surrounding the Sun (which occupies a larger world tube distant from that of the Earth).
A person standing on the surface of the Earth is described by a worldline (or a world tube with a much, much smaller diameter) that runs parallel to the Earth's world tube and just touching its boundary. An object freely falling in the Earth's vicinity is described by another worldline (or world tube with small diameter) that is not parallel to the Earth's world tube. The latter worldline is a geodesic. There are also other geodesics, much farther from Earth, that are much closer to being parallel to the Earth's world tube, because spacetime out there is much closer to being flat.
Likes Motore and PeroK
  • #33
I'm confused. Wouldn't the person's tube be spiraling around the Earth's tube, since the Earth is rotating on its axis?
  • #34
Yes, that's correct. I was thinking of an idealized non-rotating planet.
Likes phinds
  • #35
Oh well, never mind. It sounds like a stupid question anyhow. What I should have said is can someone lead me through the process. But I'm sure you must be ready to tear your hair our with me so I'll thank you all and let the matter drop.
