Gravity's Pull: How Far is the Proton Above the Electron?
An electron is held in place by the attractive force of a proton positioned above it, counteracting the force of gravity. To determine the distance between the proton and the electron, relevant equations must be identified and applied. A sketch illustrating the forces acting on the electron can aid in visualizing the problem. The discussion emphasizes focusing on the two primary forces at play, excluding the gravitational interaction between the proton and the electron. Understanding the balance of these forces is crucial for solving the problem.
Johann0101
New poster has been reminded to show their work on schoolwork problems
An electron is held up against the force of gravity by attraction of a fixed proton some distance above it. How far above the electron is the proton?
Electrical force, Electric Fields equations.
Hello @Johann0101 ,
:welcome: !​
PF is here to help you with your exercises, not to do them for you. See guidelines.
So we want you to list the relevant equations and post an attempt at solution.
What equations do you have available in your toolkit that could help you here ?
What also helps: make a sketch of the situation and draw a few forces :smile:
Likes Vanadium 50 and Delta2
Focus your attention at the electron. Which are the two forces that act upon it? (neglecting the gravitational force between the proton and the electron which would give a 3rd force.) What should be the difference of these two forces since the electron is held fixed in its position?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
