MHB Gre.al.13 sum of even and odd numbers
  • Thread starter Thread starter karush
    even Numbers Sum
The discussion centers on determining conditions under which the sum of two integers, m and n, is always odd. It is established that if m is odd and n is even, or vice versa, the sum will be odd. Conversely, if both integers are odd or both are even, the sum will be even. The user expresses uncertainty about the underlying theory but attempts to illustrate the concepts with examples. The consensus indicates that option e, where m is odd and n is even, is the correct condition for achieving an odd sum.
karush
MHB
$\tiny{gre.al.13}$
For which of the following conditions will the sum of integers m and n always be an odd integer.?
a. m is an odd integer
b. n is an odd integer
c. m and n both are odd integers
d. m and n both are even integers
e. m is an odd integer and n is an even integerI chose e just playing with numbers
don't know the exact theory on this
Mathematics news on Phys.org
Say m and n are even. Then we can say that m = 2p and n = 2q. So m + n = 2p + 2q = 2(p + q), which is even.
Say m is odd and n is odd. Then we can say m = 2p + 1 and n = 2q + 1. Etc.
-Dan
got it
never liked number theorem questions
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
