MHB GRE.al.4 Find the domain of \sqrt{x^2-25}
  • Thread starter Thread starter karush
    Domain
The domain of the function f(x) = √(x² - 25) is determined by the condition that the expression under the square root must be non-negative, leading to the inequality x² - 25 ≥ 0. This simplifies to |x| ≥ 5, which results in two intervals: x ≤ -5 and x ≥ 5. Therefore, the correct domain is represented as {x | x ≤ -5 or x ≥ 5}. While the discussion briefly touches on the possibility of including complex numbers, the primary focus remains on the real number solutions. The final conclusion is that the domain is restricted to real numbers outside the interval (-5, 5).
karush
MHB
$\tiny{GRE.al.4}$
Find the domain of $f(x)=\sqrt{x^2-25}$
a. $[x\le-5]U[x\ge 5]$
b. x=5
c. $5 \le x$
d. $x\ne 5$
e. $\textit{all reals}$
well just by observation because of the radical I chose c.
but was wondering if imaginary numbers could be part of the domain alto it is not asked for here
https://dl.orangedox.com/QS7cBvdKw55RQUbliE
Mathematics news on Phys.org
$x^2-25 \ge 0 \implies x^2 \ge 25 \implies |x| \ge 5$
also, look at the graph of $y = x^2-25$
you want to try another choice?
oh because x can be $\pm 5$ and outside the graph so a.
Since you ask about complex numbers, if all complex numbers are allowed as values for this function then its domain is "all complex numbers".
In order that this question make sense, we must be requiring that the function value, $\sqrt{x^2- 25}$ be a real number. That means that $x^2- 25\ge 0$.
$x^2- 25= (x- 5)(x+ 5)\ge 0$.
The product of two numbers is positive if and only if the two numbers have the same sign- both postive or both negative.
x- 5 and x+ 5 are both positive, x- 5> 0 and x+ 5> 0 so x>5 and x> -5. Of course, if x> 5 then x is also greater than -5 so $x\ge 5$ is a solution.
x- 5 and x+ 5 are both negative, x- 5< 0 and x+ 5< 0 so x< 5 AND x< -5. Of course, if x< -5 then x is also less than 5 so $x\le -5$ is a solution.
The solution set is $\{x| x\le -5 or x\ge 5\}$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
