-gre.al.9 absolute value domain
In summary, the solution for $|y+3|\le 4$ is given by $-7\le y\le 1$, which can be obtained by subtracting 4 from each part of $-4\le y+ 3\le 4$. This problem can be solved more quickly if we know the property $|x| \le a \implies -a \le x \le a$ for $a \ge 0$.
karush
MHB
3,269
Solve for y: $\quad |y+3|\le 4$
a.$\quad y \le 1$
b.$\quad y\ge 7$
c.$\quad -7\le y\le1$
d. $\quad -1\le y\le7$
e. $\quad -7\ge y \ge 1$
Ok I think this could be solved by observation but is risky to do so...
since y can be either plus or minus y would be between 2 -7\ge y \le 1 thus a and b are not answers
\begin{array}{l|l}
(y+3)=4&-(y+3)=4\\
y=4-3&-y=4+3\\
y=1&y=-7
\end{array}
thus
$-7\le y \le 1$
which is c.
Mathematics news on Phys.org
[sp]
The distance between $y$ and $-3$ is at most $4$. That means $y$ is between $-3-4=-7$ and $-3+4=1$.
[/sp]
$|y+ 3|\le 4$ is equivalent to $-4\le y+ 3\le 4$. Subtracting 4 from each part:
$-7\le y \le 1$.
well that's a lot quicker
mahalo btw how would you rate this problem easy, medium, hard
easy, if you know $|x| \le a \implies -a \le x \le a$ for $a \ge 0$
$-7\le y \le 1$.
mahalo
Mahalo
FAQ: -gre.al.9 absolute value domain
What is the definition of an absolute value domain?
An absolute value domain is a mathematical concept that represents the distance of a number from zero on a number line. It is always a positive value and is denoted by vertical bars around the number.
How do you solve absolute value equations in an absolute value domain?
To solve an absolute value equation in an absolute value domain, you must first isolate the absolute value expression on one side of the equation. Then, you can rewrite the absolute value expression as two separate equations, one with a positive value and one with a negative value. Finally, solve each equation separately to find the solutions.
What is the purpose of using an absolute value domain in mathematics?
The absolute value domain is commonly used in mathematics to represent the magnitude or size of a number, without considering its direction. It is also used to simplify calculations and solve equations involving negative numbers.
How is the absolute value domain related to real numbers?
The absolute value domain is a subset of the real numbers. It includes all positive and negative real numbers, as well as zero. The absolute value of a real number is always a positive real number.
Can the absolute value domain be applied to complex numbers?
No, the absolute value domain is not applicable to complex numbers. Complex numbers have a magnitude and direction, so they cannot be represented by a single positive value like in an absolute value domain.
