Greater electric potential but less electric potential energy?
In summary, the electric potential at point A is greater than the electric potential at point B. This is because point A is closer to the high potential end of the capacitor, resulting in a greater electric potential energy for an electron at point A than at point B. Additionally, when discussing forces on charged particles, it is important to take into account the sign of the charge, as it affects the direction of the force and the work done on the system.
Lo.Lee.Ta.
217
Greater electric potential but less electric potential energy??
The picture in my book looks like this:
1. The electric potential at pt. B in the parallel-plate capacitor shown here is less than the electric potential at pt. A by 4.50V. The separation between pts. A and B is .120cm, and the separation between the plates is 2.55cm.
Question:
Is the electric potential energy of an electron at pt. A greater than or less than its electric potential energy at pt. B?2. My book says electric potential energy (U) is comparable to gravitational potential energy.
So if you move a charged particle in the opposite direction of the electric field, it is like lifting a ball in the opposite direction of the gravitational field.
Since both the charged particle and ball are further away from the electric/gravitational field, the potential energy increases.
Increasing the distance between the ball and the ground releases more energy when it falls.
Similarly, increasing the distance between a charged particle and the electric field releases more energy when the particle falls.
This is what a garnered from reading the book... Let me know if I'm understanding wrong...
From the picture, it looks like an electron at point A would have a greater distance to fall than an electron at point B.
So why wouldn't the electric potential energy at A be greater than at B?The answer is that B's electric potential energy is GREATER that A's!...This makes no sense to me... =_=
Would someone please explain this to me?
Thank you so much! :)
Electrons have negative charge, as opposed to positive charge. How does that fit into all this? :wink:
If you were to put an electron at point A, what direction is the electric force? When you slowly move the electron to point B, are you moving the electron in the same direction as the electric force or against it? How does that compare with the gravity/ball analogy?
Okay, so even though our electric field flows from top to bottom (+ to -) in the picture, our charged particle can move differently?
Since we are dealing with electrons (-), they flow towards the positive region.
So our electrons flow against the electric field, from bottom to top (- to +)?
Now, is it safe to say that the (+) end of a capacitor is always the HIGH electric potential region, and the (-) end of the capacitor is always the LOW electric potential region?
This electric potential energy part I still don't understand, though! #=_=
My thinking is this:
If [itex]\downarrow[/itex]E and [itex]\uparrow[/itex](-)particle,
then energy is needed to counteract electric field, causing Kinetic Energy to increase, Work done by the electric field to decrease, and Potential Energy to increase (+ΔU).
I would compare this to lifting a ball against the gravitational field- it requires kinetic energy but gains potential energy.
So it still seems like B would have lower electric potential energy, and A would have higher electric potential energy.
(ex. B closer to ground and A higher off ground) <--My rationale...
Confused. :confused: Help please? Thanks!
I wouldn't describe a static (by that I mean unchanging with time), electric fields as "flowing." It's just there. It points in a certain direction (for a given point in space). But it doesn't flow. It just sits there pointing.
Also, for this particular problem, don't consider the electron as flowing either. Yes, there are forces on the electron: there's the electric force on the electron, and if the electron is not accelerating, there's some other force counteracting the electric force, holding it in place. Let's concentrate on the latter and assume that somehow or another you are able to hold the electron in place, and perhaps slowly move it from A to B.
The force on a charge particle q is
[tex] \vec F = q \vec E [/tex]
So what's the relationship between the force and the electric field if q is negative?
Yes, that sounds like a reasonable thing to say.
Thinking about things in terms of work is good. :smile: Very nice.
Recall,
[tex] \Delta W = \vec F \cdot \vec{\Delta s} [/tex]
where [itex] \vec{\Delta s} [/itex] is a measure of displacement.
So if you slowly move the electron in a direction which opposes the electric force (we move it slowly so we don't have to worry about kinetic energy), all the work done goes into the system's potential energy. (Or if we move the electron such that it is in the same direction as the electric force, the electric force does work on you, decreasing the system's potential energy.)
(+) Particle~ proton
[itex]\vec{F}[/itex] = q[itex]\vec{E}[/itex]
Since everything is positive, the Force and [itex]\vec{E}[/itex] point in the same direction?
(-) Particle~ electron
[itex]\vec{F}[/itex] = -q[itex]\vec{E}[/itex]
[itex]\vec{E}[/itex] and the force of the electron point in opposite directions.
The electron goes from B to A to high potential (+) region. A is closer to its destination than B.
(I'm thinking of the high potential end as the ground and A and B as an objects away from the ground.)
Since B is further off the "ground," it would have greater electric potential energy.
Is this right?
Thanks! :)
Yes, that's right. Very nice. :approve:
Yes, A has the higher electric potential. (Not necessarily to be equated with higher potential energy -- certainly not in this case anyway.)
Is this right?
Thanks! :)
Yes, an electron at location B has a higher potential energy than it would if it were at location A (only concerning ourselves with electrostatic forces).
I sympathize with you that the naming of "electric potential" was a poor choice of naming to describe the phenomenon. It's so easily confused with "potential energy" by its name. You are not alone in being a bit confused by naming. Unfortunately, it's probably here to stay. "Electric potential" is so ingrained in the vernacular of the subject that there's no chance of it changing any time soon. Just try to keep in mind that "electric potential" and "potential energy," while related, are separate concepts.
If it helps, electric potential gives you the potential energy of a positive test charge. But it has to be a positive test charge. If the charge you are working with is negative, the potential energy needs to flip signs too, for the same electric potential.
Related to Greater electric potential but less electric potential energy?
1. What is the difference between electric potential and electric potential energy?
Electric potential is a measure of the electric potential energy per unit charge at a specific point in an electric field. Electric potential energy, on the other hand, is the potential energy that a charged object has due to its position in an electric field.
2. How can there be a greater electric potential but less electric potential energy?
This can occur when the distance between two charged objects increases. The electric potential may increase due to the increased charge, but the electric potential energy decreases because the distance between the objects has increased.
3. Can electric potential and electric potential energy have opposite signs?
Yes, they can. Electric potential is a scalar quantity and can have either positive or negative values, while electric potential energy is a vector quantity and can also have either positive or negative values.
4. How are electric potential and electric field related?
Electric potential is directly related to the electric field by the equation V = Ed, where V is the electric potential, E is the electric field, and d is the distance between the two points. This means that the electric field is the gradient of the electric potential.
5. Can we measure electric potential and electric potential energy?
Yes, both electric potential and electric potential energy can be measured using appropriate instruments. Electric potential can be measured using a voltmeter, while electric potential energy can be measured using an electroscope or a capacitance meter.
