MHB Greatest common divisor of two polynomials
Math Amateur
MHB
I am working on Exercise 8 of Dummit and Foote Section 9.2 Exercise 8
Determine the greatest common divisor of a(x) = x^3 - 2 and b(x) = x + 1 in \mathbb{Q} [x]
and write it as a linear combination (in \mathbb{Q} [x] ) of a(x) and b(x).
In working on this I applied the Division Algorithm to a(x) and b(x) resulting in x^3 - 2 = (x^2 - x + 1) (x+ 1) + (-3)
then
(x + 1) = (1/3 x + 1/3) + 0Last non-zero remainder is -3
Therefore, gcd is -3
BUT!
This does not seem to be correct because -3 does not divide either a(x) and b(x)
Can someone please help?
Peter
then
BUT!
Peter
$-3$ is a unit in $\mathbb{Q} [x]$, so is equivalent to $1$. You have shown that $$-\tfrac13(x^3-2) + \tfrac13(x^2-x+1)(x+1) = 1.$$ Thus $p(x)a(x)+q(x)b(x) = 1$, where $p(x) = -\frac13$ and $q(x) = \frac13(x^2-x+1)$. The polynomials $p(x)$ and $q(x)$ are both in $\mathbb{Q} [x]$.
I am an amateur but i tried doing your problem the way they do it here.
http://www.math.niu.edu/~beachy/abstract_algebra/study_guide/soln4.html
wolfram confirms their answer so it appears wolfram is giving answers over Q[x] for gcd command.
gcd (x^8-1, x^6 - 1) - Wolfram|Alpha
I am not encouraging you to cheat but WIA can be a valuable resource to check your work AFTER you get an answer by manual computation.
For your question WIA gives 1 as gcd.
gcd (x^3-2, x + 1) - Wolfram|Alpha
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
