Greenhouse Gas Misunderstanding?
In summary, the conversation discusses the role of carbon dioxide in absorbing energy from the sun's radiation and preventing it from escaping into space, similar to a glass greenhouse. The IR absorption is strongest in molecules with two different types of atoms such as CO2 and H2O. This process may contribute to global warming, but there is also a potential for CO2 to cause global cooling by preventing heat from reaching deeper layers of the Earth's surface. The experts suggest that CO2 may not directly absorb visible light, but rather absorbs infrared radiation.
Impavid
Okay so I am a first time poster, hello to my fellow scientists.
I need an expert opinion on a simple question I can't get around: I understand that Carbon Dioxide will absorb more energy from whatever radiation it comes into contact with than, say, Oxygen. That being said, I imagine the light (and other radiation/particles) breaching the atmosphere, making contact with a CO2 particle, transferring heat to it, hitting the ground, again transferring heat, going back up hitting another CO2 particle, transferring heat, and MAYBE by chance getting reflected and the efficiency of absorption is thus increased... however...
If the particle 10 miles in the atmosphere absorbs more heat, we must remember that in physics all energy transferred will be equal to energy lost in whatever your causation is. Therefore, the light has less energy than it would have had if it had not made contact with any CO2 by the time it hit the ground. After going through a greenhouse atmosphere, the energy from what gets through is weakened, and the ground itself absorbs less heat. Now here's where it all comes together...
Maybe CO2 increases the total amount of heat absorption for the Earth when we tally the numbers, but wouldn't heat transferred to an atom 10 miles above the surface virtually do nothing to heat the particles 10 miles below it? Wouldn't it be more beneficial to the earth, due simply to the insulation miles of atmosphere, for the light to transfer the bulk of its energy as deep under the Earth's skin as possible? (so as for the heat to actually have to escape to other atoms around it, which is difficult for atoms in high atmosphere because they are so incredibly far apart by comparison.)
Therefore, wouldn't CO2 cause global cooling??
Someone enlighten me. Much appreciated.
CO2 doesn't directly absorb (much) visible light.
The light from the sun goes through the atmosphere and heats the Earth's surface. The Earth then re-radiates this as infrared - which CO2 strongly absorbs, preventing the energy escaping into space and heating the atmosphere.
The IR absorption is strongest in molecules which have two different types of atoms (CO2, H2O), these bonds can vibrate at a frequency that is in the infrared band - atoms with the same element (O2 N2) have different bond energies.
The same effect happens in a glass greenhouse, sunlight goes straight through the glass on the way in and heats the inside, the infrared from the inside is blocked by the glass on the way back out.
Dear fellow scientist, thank you for sharing your thoughts on this topic. It seems like you have a good understanding of the physics behind greenhouse gases and their role in the Earth's atmosphere. However, there are a few misunderstandings that I would like to address.
Firstly, it is important to note that the Earth's atmosphere is not a closed system. This means that energy from the Sun is constantly entering and leaving the Earth's atmosphere. The role of greenhouse gases, such as carbon dioxide, is to trap some of this energy and prevent it from escaping back into space. This is known as the greenhouse effect and without it, the Earth's average temperature would be much colder.
Secondly, while it is true that some of the energy from the Sun is absorbed by greenhouse gases in the upper atmosphere, it is not completely lost. This energy is eventually re-radiated back into the atmosphere, some of which makes its way back to the Earth's surface, contributing to the overall warming effect.
Additionally, the Earth's surface and lower atmosphere are constantly exchanging energy through processes such as convection and conduction. So even if the energy is initially absorbed by greenhouse gases in the upper atmosphere, it can still contribute to heating the lower atmosphere and the Earth's surface.
In summary, while it may seem counterintuitive, greenhouse gases actually contribute to warming the Earth's surface and lower atmosphere. Without them, the Earth would be much colder and potentially uninhabitable for most forms of life. I hope this helps to clarify any misunderstandings and I encourage you to continue exploring this topic further.
FAQ: Greenhouse Gas Misunderstanding?
What are greenhouse gases?
Greenhouse gases are gases that trap heat in the Earth's atmosphere, contributing to the greenhouse effect. These gases include carbon dioxide, methane, nitrous oxide, and fluorinated gases.
Why are greenhouse gases a concern?
Greenhouse gases are a concern because they contribute to climate change and global warming. As these gases trap heat in the atmosphere, they cause the Earth's temperature to increase, leading to various environmental and societal impacts such as rising sea levels, extreme weather events, and disruptions to ecosystems.
How do greenhouse gases affect the environment?
Greenhouse gases affect the environment by trapping heat in the atmosphere, leading to a warmer climate. This can cause changes in weather patterns, such as more intense and frequent heat waves, droughts, and storms. It also contributes to the melting of polar ice caps and glaciers, which leads to rising sea levels.
What are some sources of greenhouse gases?
Greenhouse gases can come from both natural and human activities. Natural sources include volcanic eruptions and decomposition of organic matter. Human activities, such as burning fossil fuels, agriculture, and deforestation, also emit large quantities of greenhouse gases into the atmosphere.
Can we reduce greenhouse gas emissions?
Yes, we can reduce greenhouse gas emissions by implementing various measures such as transitioning to renewable energy sources, improving energy efficiency, and implementing sustainable land use practices. It is essential to reduce greenhouse gas emissions to mitigate the impacts of climate change and work towards a more sustainable future for our planet.
