I Green's function for 2-D Laplacian within square/rectangular boundary
Swamp Thing
Insights Author
From the table of Green functions on Wikipedia we can get the generic 2-D Green's function for the Laplacian operator. But how would one apply boundary conditions like u = 0 along a rectangular boundary? Would we visualize a sort of rectangle-based, tilted pyramid, with logarithmically changing height, with its apex located at our Dirac driving point?
Generally in that case one would look for an eigenfunction expansion, with the eigenfunctions satisfying <br /> \nabla^2 \phi_{nm} = \lambda_{nm}\phi_{nm} subject to \phi_{nm} = 0 on the boundary. These turn out to be products of trigonometric functions which are orthogonal with respect to the inner product <br /> \langle f, g \rangle = \int \int f(x,y)g(x,y)\,dx\,dy and the solution of \nabla^2 u = f is u = \sum_{n,m} a_{nm} \phi_{nm} where <br /> \lambda_{nm}a_{nm}\|\phi_{nm}\|^2 = \langle f, \phi_{nm} \rangle.
Likes Swamp Thing
By setting f(x,y) = \delta(x - s)\delta(y - t) we can recover the Green's function <br /> G(x,y;s,t) = \sum_{n,m} \frac{\phi_{nm}(s,t)\phi_{nm}(x,y)}{\lambda_{nm}\|\phi_{nm}\|^2}. and indeed <br /> u(x,y) = \iint_A G(x,y;s,t)f(s,t)\,ds\,dt = \sum_{n,m} \frac{\langle f, \phi_{nm}\rangle}{\lambda_{nm}\|\phi_{nm}\|^2} by swapping summation and integration.
Thanks for the help!
I am new to this, so maybe this is a silly question...
I am trying this in Mathematica:
Code:
X = 10; Y = 10;
gf = GreenFunction[{-Laplacian[u[x, y], {x, y}],
   DirichletCondition[u[x, y] == 0, True]},
  u[x, y], {x, y} \[Element] Rectangle[{0, 0}, {X, Y}], {m, n}]
Plot3D[gf /. {m -> 0.7 X, n -> 0.3 Y} /. {\[Infinity] -> 50} //
   Activate // Evaluate, {x, 0, X}, {y, 0, Y}, PlotRange -> All]
Which gives this expression for the Green Function:
\frac{1}{25} \underset{K[1]=1}{\overset{\infty }{\sum }}\underset{K[2]=1}{\overset{\infty }{\sum }}\frac{\sin \left(\frac{1}{10} m \pi K[1]\right) \sin \left(\frac{1}{10} \pi x K[1]\right) \sin \left(\frac{1}{10} n \pi K[2]\right) \sin \left(\frac{1}{10} \pi y K[2]\right)}{\frac{1}{100} \pi ^2 K[1]^2+\frac{1}{100} \pi ^2 K[2]^2}
I am not sure about which symbols in Mathematica's formula correspond to which ones in your post. I am guessing, for example, that your m's and n's correspond to the K[1] and K[2] in the above formula? I have figured out that the m and n in the above correspond to the coordinates of the point excitation (Dirac function) but I am not sure of some of the other symbols in your post.
It's best not to use m and n as real-valued quanties; by convention they are used as integer variables and doing otherwise will confuse people.
For your particular boundary conditions, the eigenfunctions are <br /> \phi_{nm}(x,y) = \sin\left(\frac{n\pi x}{10}\right)\sin\left(\frac{m\pi y}{10}\right) which has \|\phi_{nm}\| = 5 and the corresponding eigenvalues are <br /> \lambda_{nm} = -\frac{\pi^2(n^2 + m^2)}{100}. The result given by Mathematica differs by a sign compared to mine, but that is explained by you asking it to solve -\nabla^2 u = \delta(x - x_0) rather than \nabla^2 \phi = \delta(x - x_0).
Yes, I think I better change the m and n to something else, like ##(x_d,y_d)## as a mnemonic that it's where the Dirac delta is located. The code I posted is from the examples in the Wolfram help page for GreenFunction.
Quick question about the usual workflow when doing this kind of problem from first principles: does the Fourier analysis help to determine the Green's function, OR, is the G.F. found by other means, after which you Fourier-analyze it in order to then get the time evolution?
Thanks again.
