Green's function for Klein-Gordno equation in curved spacetime
The discussion focuses on the possibility of defining retarded and advanced Green's functions in curved spacetime without relying on a timelike Killing vector. It is suggested that these functions can be expressed using only causal structure, eliminating the need for a time coordinate. The retarded Green's function is typically defined as zero unless the time condition t' < t is met. However, the causal structure allows for determining the relationship between points in spacetime without this temporal constraint. Overall, the conversation emphasizes the feasibility of defining these functions through causal relationships.
paweld
Is it possible to define unambiguously retarded and advanced Green's function
in spacetime without timelike Killing vector. Most often e.g. retarded Green
function G_R(t,\vec{x},t&#039;,\vec{x}&#039;) is defined to be 0 unless t'<t
but maybe one can express this condition using only casual structure
(without time coordinate)?
Yes, this can be done using the causal structure. You don't need a Killing vector to decide if two points are in the past or future of each other (or are spacelike-separated). A good practical introduction to Green's functions in curved spacetimes may be found in http://relativity.livingreviews.org/Articles/lrr-2004-6/" .
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 38 ·
