Green's Function with repulsive force
In summary, the Green's function for an object subject to a linear repulsive force is given by ##G(t-t^\prime)=\frac{1}{m\gamma}sinh(\gamma(t-t^\prime))##, where ##\gamma=\sqrt{\frac{k}{m}}## and ##m\ddot{x}(t) = kx(t)##. This equation can be derived from the fact that ##F=kx## and the equation for the Green's Function, ##x(t)=\int_0^tG(t-t^\prime)F(t^\prime)dt^\prime##. The hint suggests that ##\ddot{x}(t)## is equal to ##\frac{1}{m
teme92
185
Consider an object subject to a linear repulsive force, ##F = kx##. Show that the Green’s function for this object is given by:
##sinhx=\frac{e^x+e^{-x}}{2}##
So when I'm trying to make the Green's Function I start with:
##F(t^\prime)=kx## so:
##x(t)=\int_0^tG(t-t^\prime)(kx)dt^\prime##
For an impulse I think ##G(t-t^\prime)=\frac{v(t-t^\prime)}{\Delta p}## where ##\Delta p = mv-0=mv##. However I don't know what to do for a repulsive force. Also I don't know how to get to the ##sinh## part. Any help would be greatly appreciated.
Hint: ##F=kx## tells you that ##m\ddot{x}(t) = kx(t)##...what does your equation for the Green's Function tell you ##\ddot{x}(t)## is?
FAQ: Green's Function with repulsive force
What is a Green's function with repulsive force?
A Green's function with repulsive force is a mathematical function that describes the behavior of a system with a repulsive interaction. It is used in many areas of physics and engineering to model complex systems.
How is a Green's function with repulsive force different from a regular Green's function?
A Green's function with repulsive force takes into account the repulsive interaction between particles, while a regular Green's function does not. This allows for a more accurate representation of the system's behavior.
How is a Green's function with repulsive force used in physics?
A Green's function with repulsive force is used in many areas of physics, such as quantum mechanics, statistical mechanics, and fluid dynamics. It is used to solve complex equations and understand the behavior of systems with repulsive interactions.
Can a Green's function with repulsive force be applied to real-world systems?
Yes, a Green's function with repulsive force can be applied to real-world systems. It has been used to model and understand the behavior of various physical systems, such as atoms, molecules, and fluids.
How is a Green's function with repulsive force calculated?
A Green's function with repulsive force is typically calculated using various mathematical techniques, such as perturbation theory, numerical methods, or variational methods. The exact method used depends on the specific system being modeled.
