Green's function with same time and spatial arguments
In summary: Peskin's book.Peskin's book has an explicit expression for the Green's function. It diverges for large momenta (UV divergence).
taishizhiqiu
63
Concerning green's function with the same time and spatial argument(i.e. ##G_0(x,t;x,t)##, mostly in QFT), I have the following question
1. Is green's function well defined at this point?
2. if green's function is well defined at this point, is it continuous here?
3. In quantum many body theory, I am instructed to view ##G_0(x,t;x,t)## as ##G_0(x,t;x,t+0^+)## in feynman diagrams. Why is this so?
The Green's functions in vacuum QFT are defined as the time-ordered products of field operators and as such a priori singular when their space-time arguments become equal. That becomes clear from the equal-time commutator relations. For some field ##\hat{\phi}## and its canonical field momentum ##\hat{\Pi}## it reads
$$[\hat{\Phi}(t,\vec{x}),\hat{\Pi}(t,\vec{y})]=\mathrm{i} \delta^{(3)}(\vec{x}-\vec{y}).$$
In non-relativistic many-body theory you have a Schrödinger field. The free field consists only of a annihilation piece, and thus the special rule given in your OP means that a closed loop connecting the same space-time point in a Feynman diagram should be interpreted as the expectation value of a normal ordered piece in the Hamiltonian, i.e., a density. This automatically subtracts the always diverging vacuum pieces of such tadpole diagrams.
Likes taishizhiqiu
Thanks for your post, still:
1. Why in QFT I am never instructed to view ##G_0(x,t;x,t)## as ##G_0(x,t;x,t+0^+)## in feynman diagrams?
2. Tadpole diagrams is divergent in QFT. Is there any relationship between ##G_0(x,t;x,t)## and the divergence?
In vacuum QFT a tadpole loop is a connection between field operators within ##\mathcal{H}_{\text{int}}##. Usually you can assume normal-ordering of the Hamiltonian and just skipt the diagram. There's one caveat: Usually (naive) normal ordering is not gauge invariant, and you cannot naively leave the diagram out. So it's more convenient to keep the diagrams and renormalize them along with the other divergences (most simple examples: tadpole diagram for the photon polarization in scalar QED; tadpole diagram in gluon polarization in QCD).
vanhees71 said:
In vacuum QFT a tadpole loop is a connection between field operators within ##\mthcal{H}_{\text{int}}##. Usually you can assume normal-ordering of the Hamiltonian and just skipt the diagram. There's one caveat: Usually (naive) normal ordering is not gauge invariant, and you cannot naively leave the diagram out. So it's more convenient to keep the diagrams and renormalize them along with the other divergences (most simple examples: tadpole diagram for the photon polarization in scalar QED; tadpole diagram in gluon polarization in QCD).
Renormalization deals with diagrams that's divergent because of large momentum(##k##). Is tadpole diagram divergent because of green's function of the same argument or because of large momentum? And what's the relationship between the two things?
Greens functions are of two types... one is retarded and other one is advanced.. retarded green's functions is causal meaning it respect Lorentz symmetry.. And then you can define Feynman propagator accordingly. Anyway the question of green's function evaluated at same time at same space physically mean I think what is the probability that a state at that particular spacetime point would collapse to the state defined at other spacetime point. So I think if Space and time both are same then It should be just 1...
No, the propagator is singular at equal space-time points. This is clear from the equal-time commutation relations for field operators. This is the origin of UV divergences in the Feynman rules.
Can you explain more explicitly why equal space-time green's function corresponds to UV divergences? You can refer to peskin's book if necessary.
Well take a free uncharged Klein-Gordon field for Simplicity. The Lagrangian is
$$\mathcal{L}=\frac{1}{2} (\partial_{\mu} \phi)(\partial^{\mu} \phi)-\frac{m}{2} \phi^2$$
and the canonical field momentum thus
$$\Pi(x)=\frac{\partial \mathcal{L}}{\dot{\phi}}=\dot{\phi}(x).$$
Thus you have
$$[\phi(t,\vec{x}),\Pi(t,\vec{y})]=\mathrm{i} \delta^{(3)}(\vec{x}-\vec{y}).$$
The time-ordered propagator (which is for vacuum QFT the Feynman propagator)
$$\mathrm{i} G(x-y)=\langle \mathcal{T}_c \phi(x) \phi(y)$$
thus has the correct Green's function property
$$(\Box_x+m^2) \mathrm{i} G(x-y) =\delta^{(4)}(x-y).$$
For an explicit expression for the Green's function, which you can evaluate via the Fourier transform from the momentum-space representation
$$G(x)=\int \frac{\mathrm{d}^4 k}{(2 \pi)^4} \frac{1}{k^2-m^2 + \mathrm{i} 0^{+}} \exp(-\mathrm{i} k \cdot x).$$
It's very clear that this integral for ##x=0## does not exist, because it diverges for large four momenta (UV divergence). You find a discussion of this integral in some detail in the beginning sections of Peskin and Schroeder.
FAQ: Green's function with same time and spatial arguments
1. What is the definition of Green's function with same time and spatial arguments?
Green's function with same time and spatial arguments is a mathematical function that describes the response of a system to a point source at a given location and time. It is used in many areas of physics, including electromagnetics, quantum mechanics, and fluid dynamics.
2. What is the significance of Green's function with same time and spatial arguments?
The significance of Green's function with same time and spatial arguments lies in its ability to provide a complete solution to a differential equation in terms of a specific boundary or initial value. It allows us to break down a complex problem into simpler equations and find a solution for each individual component before combining them to obtain the overall solution.
3. How is Green's function with same time and spatial arguments calculated?
The calculation of Green's function with same time and spatial arguments depends on the specific system and its governing equations. In general, it involves solving the differential equation with a point source at the specified location and time, and then taking into account the boundary conditions to obtain the final form of the function. In some cases, the function can also be obtained through a Fourier transform or other mathematical methods.
4. What are the applications of Green's function with same time and spatial arguments?
Green's function with same time and spatial arguments has many applications in physics and engineering. It is commonly used in solving problems related to heat transfer, wave propagation, and potential theory. It also plays a crucial role in the study of quantum mechanics and electromagnetism, and is utilized in the development of computational models and simulations.
5. What are the limitations of Green's function with same time and spatial arguments?
Although Green's function with same time and spatial arguments is a powerful tool in solving differential equations, it has its limitations. For example, it may not be applicable to systems with complex geometries or non-linear behavior. In addition, the calculation of Green's function can be challenging and time-consuming for certain systems, requiring advanced mathematical techniques and computer programming skills.
