Griffith's EM third ed. pp.68 equ 2.12
  • Thread starter quasar987
  • Tags
    Em
In summary, Griffith's EM third edition has a section on point charges and their flux through spheres. The flux is calculated using the integral over a sphere of the charge's flux through a small surface element. The area of a sphere is 4 pi r^2, so the flux is 8 pi r dr. In summary, the book gets you confused, and the notation is misleading.
quasar987
32
Griffith's EM third ed. pp.68 equ 2.12 ...
"In the case of a point charge q at the origiin, the flux of E though a sphere of radius r is
[tex]\int \vec{E} \cdot d\vec{A} = \int \frac{q}{4\pi\epsilon_{0}r^2}\hat{r} \cdot (r^2sin\theta \ d\theta \ d\phi \ \hat{r})[/tex]"
How the hell is dA equal to that? Multiply dr to it and it's dV in spherical coord. The area of a sphere is 4 pi r^2. Shouldn't dA be 8 pi r dr?
You have to consider a small surface element.
You can see it as rectangle of sides [itex]r d\phi[/itex] and [itex]r\sin \theta d\theta[/itex]. So the area element is: [itex]r^2\sin \theta d\theta d\phi[/itex].
You can check that this will give the right area for the sphere:
[tex]A=\int_0^{2\pi}\;\; \int_0^{\pi}r^2\sin \theta d\theta d\phi=4\pi r^2[/tex]
The only way I know how to derive it rigorously is by using calculus:
Parametrize the sphere as:
[tex]\vec r(\theta,\phi)=\sin \theta \cos \phi \vec i +\sin \theta \sin \phi \vec j + \cos \theta \vec k \qquad 0 \leq \theta \leq \pi , \quad 0\leq \phi \leq 2\pi[/tex]
And calculate [tex]dA=|\vec r_{\theta} \times \vec r_{\phi}|d\theta d\phi[/tex] (the Jacobian of the transformation). That'll give the right answer.
I`m sure there are more clever ways to do it though.
Mmh, ok I see it now.
It is unfortunate that both the surface element ([itex]r^2\sin \theta d\theta d\phi[/itex]) of a sphere and the infinitesimal increase in area of the sphere ([itex]8\pi r dr[/itex]) have the same notation.
...the infinitesimal increase in area of the sphere ([itex]8\pi r dr[/itex])...
^^What is that? Besides, it is never mentioned in Griffiths, so how is it unfortunate?
I remember seing it pretty easily through the first method prescribed by Galileo...Geometry in this case does more than calculus...Sure,for the volume element,i'd still reccomend the jacobian...
Daniel.
P.S.That notation with "hats" to designate unit vectors sure got me fooled...
cepheid said:
^^What is that?
What I had in mind is that... The area of a sphere is [itex]A = 4\pi r^2[/itex]. So if you differentiate A with respect to r, you get the rate of chage of the area with respect to radius: [itex]\frac{dA}{dr}=8\pi r[/itex]. Or, multiplying both sides by dr, you get a differential equation, or function (in the sense that the differential dr is a variable): [itex]dA = 8\pi r dr[/itex]. This is saying that for a small increment of radius [itex]\Delta r[/itex], the area increases approximately according to the equation [itex]\Delta A = 8 \pi r \Delta r[/itex]... and the smaller the [itex]\Delta r[/itex], the more precise the approximation. Or, we could say that for a [itex]\Delta r[/itex] infinitely small (i.e. infinitesimal) it is no longer an approximation.
It is unfortunate because it got me confused! :smile: dA of a surface could either be understood as the dA above (increment in area), or as an element area: [itex]dA = dxdy[/itex]. This is why, I think, it is important to write the surface integrals as double integrals [itex]\iint f dA[/itex] (something Mr. Griffiths neglects), so that we don't confuse the "surface element" dA with the "area increment" dA.
What do i get the feeling that u and only u may mistankenly take the area element as a differential area increment...?? :-p The notation is misleading,i admit,i always denote the former by [itex] dS [/itex] or even [itex] d\vec{S} [/itex] (orientable surfaces are common in physics),while the latter is simply [itex] dA [/itex].
It's the book's fault,but not totally... :rolleyes:
Daniel.
Of course, I was tired and my thoughts were foggy... but bookwritters should take this possible state of their readers into account! :biggrin:
FAQ: Griffith's EM third ed. pp.68 equ 2.12
What is Griffith's EM third edition pp.68 equ 2.12?
Griffith's EM third edition pp.68 equ 2.12 refers to a specific equation found on page 68 of the third edition of the textbook "Introduction to Electrodynamics" by David J. Griffiths. This equation, also known as equation 2.12, is used to calculate the electric and magnetic fields produced by a moving point charge.
What does the equation represent?
The equation, also known as the Lienard-Wiechert potential, represents the electric and magnetic fields produced by a moving point charge at a given point in space and time. It takes into account the speed and acceleration of the charge, as well as the distance between the charge and the point of observation.
How is this equation derived?
This equation is derived from Maxwell's equations, which describe the fundamental principles of electromagnetism. By applying the Lorentz transformation and taking into account the finite speed of light, the Lienard-Wiechert potential is obtained.
What are some applications of this equation?
This equation has many applications in the fields of electrodynamics and electromagnetism. It is used in studying the behavior of particles moving at relativistic speeds, in the design of antennas and other electromagnetic devices, and in calculating the fields around charged particles in particle accelerators.
Are there any limitations to this equation?
Like any mathematical model, this equation has its limitations. It assumes that the charge is a point particle, and does not take into account the effects of quantum mechanics. It is also a classical model and does not account for any relativistic effects such as time dilation or length contraction.
