[Griffiths ex4.2] Electric field of a uniformly polarized sphere
In summary: The polarized sphere can be seen as a combination of a shell with surface charge ##\sigma_b## and a solid sphere with volume charge ##\rho_b##. This allows us to use the equations and theories we already know for those cases. However, we must be careful to take into account the non-uniformity of the surface bound charge density when calculating the electric field inside the sphere. In summary, Griffiths explains in section 4.2.1 that the field produced by a polarized material can be calculated by considering it as a combination of two objects: a shell with surface charge density ##\sigma_b## and a solid sphere with volume charge density ##\rho_b##. However, it is important to note
peguerosdc
28
Find the electric field produced by a uniformly polarized sphere of radius R
##\sigma_b = \boldsymbol{P} \cdot \boldsymbol{\hat{n}}##
##\rho_b = - \nabla \cdot \boldsymbol{P} ##
Hi!
This is more a conceptual question rather than the calculation itself.
So, Griffiths' section 4.2.1 "The field of a polarized object / Bound charges" says that if you want to calculate the field produced by a polarized material, you can find it from the potential of a surface charge and a volume charge like this:
## V(\mathbf{r}) = \frac {1} {4\pi\epsilon_0} \oint \frac {\sigma_b} {r - r'} da' + \frac {1} {4\pi\epsilon_0} \int \frac {\rho_b} {r - r'} d\tau' ##
which are called "bound charges".
As I understand this, it means that you can see the polarized object as a combination of two objects i.e. for the case of a polarized sphere of radius R, you can consider it as a shell of radius R with a surface charge density ##\sigma_b## and a solid sphere of radius R with volume charge density ##\rho_b## and use all the theory we already know for those cases i.e. Gauss's law (if useful), definition of E, etc.
Is this correct? The reason I ask (and the reason I suspect it is not) is because in example 4.2, Griffiths asks you to find the electric field produced by a uniformly polarized sphere of radius R, but as the sphere is uniformly polarized, then ##\rho_b=0##, so it should mean that I can consider the polarized sphere as only a spherical shell with charge density ##\sigma_b##, right?. If my assumption is correct, then the electric field inside the polarized sphere should be 0 (as it would be the field only due to the spherical shell) but NO! Griffiths says there is a non-constant potential inside the polarized sphere and, thus, a non-zero electric field inside.
Then, why is my assumption of making a polarized object a combination of surface + volume objects not correct if, apparently, from the equation of V it should?
The surface charge density is not uniform, so the field inside is not zero.
Following what @PeroK says, the surface bound charge density [itex] \sigma_b \neq \overrightarrow{(constant)}[/itex].
Why is this so? What is your definition of [itex] \sigma_b [/itex]?
The definition is ##\sigma_b = \vec P \cdot \hat n = P \cos(\theta) ## so, right! It is not uniform so the field is not zero inside the sphere.
Such an obvious error, but lesson learned: if P is uniform, that doesn´'t mean the densities are going to be uniform. Thanks!
Besides from that, just to confirm, is my assumption that we can now consider the problem as a combination of surface + volume objects correct?
Likes PeroK
Yes, that's the whole point.
Related to [Griffiths ex4.2] Electric field of a uniformly polarized sphere
1. What is the formula for the electric field of a uniformly polarized sphere?
The formula for the electric field of a uniformly polarized sphere can be expressed as E = (1/4πε₀) * (3P - rPcosθ)/r³, where P is the dipole moment of the sphere, r is the distance from the center of the sphere, and θ is the angle between the dipole moment and the position vector.
2. How does the electric field of a uniformly polarized sphere differ from that of a point charge?
The electric field of a uniformly polarized sphere is different from that of a point charge because it takes into account the dipole moment of the sphere, whereas a point charge only has a single charge at its center. This results in a more complex and non-uniform electric field around the sphere.
3. Can the electric field of a uniformly polarized sphere be affected by an external electric field?
Yes, the electric field of a uniformly polarized sphere can be affected by an external electric field. The external electric field can cause the dipole moments of the sphere to align in a different direction, resulting in a change in the overall electric field of the sphere.
4. How does the electric field of a uniformly polarized sphere change with distance from the center?
The electric field of a uniformly polarized sphere follows an inverse distance relationship, meaning that it decreases as the distance from the center of the sphere increases. This is similar to the electric field of a point charge.
5. Can the electric field of a uniformly polarized sphere be zero at any point?
Yes, the electric field of a uniformly polarized sphere can be zero at certain points. This occurs when the dipole moment of the sphere is aligned with the position vector, resulting in a cancellation of the electric field. These points are known as neutral points.
