Griffiths Quantum Mechanics Problem 1.18: Characteristic Size of System
The discussion centers on the interpretation of intermolecular distance in Griffiths' Quantum Mechanics Problem 1.18, contrasting a spherical model with a cubic box model. The volume per particle is represented differently in each model, leading to a significant factor difference of approximately 1.8. Participants agree that while a box may not fill space completely with spherical particles, it is often used for computational simplicity. The conversation highlights the importance of choosing an appropriate shape for accurate modeling in quantum mechanics. Ultimately, the choice of shape affects the understanding of particle distribution in a given volume.
yucheng
The characteristic size (length) of ideal gas where quantum effects are non-negligible is the intermolecular distance, ##d##
##pV = Nk_BT##
intermolecular distance means distance between particles. So, I imagine a sphere.
$$\frac{4}{3} \pi d^3 = \frac{V}{N}$$
However, Griffitfhs pictures a box instead, where
$$d^3 = \frac{V}{N}$$
And the difference between both models is a factor of ##(4\pi/3)^{2/5} \approx 1.8##, which is fairly large...
If you fill a box with oranges, does it fill the space completely? Griffiths is correct
I think I understand... So I guess I should have searched for a reliable shape to fill the whole space!
And usually we imagine the box to be square, for computational convenience...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
