Jdo300
- 554
- 5
Hello All,
I was talking to a friend about how to properly isolate a digital board from a high-powered output stage. The output stage in my application make square wave pulses that can be as high as 500V. So my first thought was to galvonically isolate the output stage circuitry from the digital board which contains a microcontroller to run it all.
Up to this point, I figured that a simple isolator (like the IL710) would work great. They are fast, and have 2500V of isolation between the input and output.
But my friend mentioned that there should be a 10 ohm resistor between the two ground planes of the digital and output stage board to keep a static voltage from building up and poping the isolator IC.
But I'm thinking that if you connect the ground planes at all, then it is kind of defeating the purpose of the isolation in the first place. But at the same time, I recognize the issue with the static voltage buildup. How do I deal with such a problem?
Thanks,
Jason O
Thanks,
Jason O
