Ground Source Heat Pump Questions
In summary, ground source heat pumps utilize a small amount of electricity to pump heated ground water or antifreeze solution through a system of piping in the ground, transferring heat from the ground to a home. This is possible because the ground temperature several meters down remains relatively constant throughout the year. The heat pump works by utilizing the thermodynamic properties of a refrigerant to generate different temperatures, extracting heat from the ground and using it to heat the home. Additional heating units may be needed to raise the temperature to a comfortable level. Environment Canada takes readings of ground temperatures, but their reports are not readily available.
blimkie.k
130
I am researching ground source heat pumps, however I do not completely understand how they work.
I understand that a pump uses a small amount of electricity to pump heated ground water or an antifreeze solution through the a system of piping in the ground to transfer heat from the ground to a home. What I don't understand how this actually heats the house to a comfortable temperature in some areas.
On this site, http://www.davocal.ie/Assets/services/eco_friendly/eco_friendly.php
it says in this country (not sure where) the ground temperature several metres down varies from 10 - 13 degrees.
This document, http://www.nrc-cnrc.gc.ca/obj/irc/doc/pubs/rp/rp33/rp33.pdf
on page 7, shows a chart that shows a chart of ground temperatures for Ottawa, Canada (which is near where i live) in clay. At 15 feet below the surface the temperature varied from 45-50 F over the year in 1954-1955.
So say the ground is around 50 F and you have your piping with antifreeze running through there, how is that going to work on its own to heat a home. Is there a way that the system can obtain a higher temperature via friction or running through the pump or would the ground heated solution need to be pumped through another heating unit above ground to give it another 15-20 degrees of heat to allow it to heat a home to a comfortable temperature.
Also I know that Environment Canada takes readings of the ground temperatures twice daily at 60,000 locations across Canada. I have been looking for there publications or reports but can't find any. Does anyone know where to find these?
The ground loop is just where the heat pump gets or dissipates its heat. It isn't what a "heat pump" is.
A heat pump is a device that uses a refrigerant to create a temperature difference which causes heat to move in the opposite direction you would normally expect it to move. For example, an air conditioner moves heat from inside your house to outside your house despite the fact that the air outside is warmer than inside (making the heat want to go from out to in).
A "heat pump" is just an air conditioner working in reverse. On a cold day, heat wants to go from inside to outside, but the air conditioner makes it go from outside to inside.
The way this is done is by utilizing the thermodynamic properties of the refrigerant to generate different temperatures. Inside your house, the pressure is raised, which heats the refrigerant. This heat is then extracted to heat your house, cooling the refrigerant back down somewhat. Then the pressure is relieved, which makes it cool even further, below the temperature of the source/sink (outside air or in your case, a water source). Then heat is put back into it from this heat source. Repeat!
http://en.wikipedia.org/wiki/Heat_pump
Related to Ground Source Heat Pump Questions
1. How does a ground source heat pump work?
A ground source heat pump works by transferring heat from the ground into a building during the winter, and transferring heat out of the building and into the ground during the summer. This is done through a series of pipes buried in the ground, which contain a mixture of water and antifreeze. The heat pump uses a compressor to circulate this mixture and extract the heat from the ground, which is then used to heat the building.
2. What are the benefits of using a ground source heat pump?
There are several benefits to using a ground source heat pump. First, it is a more energy-efficient way to heat and cool a building compared to traditional methods. It also has a lower carbon footprint, as it doesn't rely on fossil fuels. Additionally, ground source heat pumps can provide hot water for domestic use, further reducing energy costs.
3. What is the difference between a ground source heat pump and an air source heat pump?
The main difference between a ground source heat pump and an air source heat pump is the source of heat they use. As the name suggests, a ground source heat pump extracts heat from the ground, while an air source heat pump extracts heat from the air. Ground source heat pumps are typically more efficient and have a longer lifespan, but they also require more space and upfront cost for installation.
4. Are there any disadvantages to using a ground source heat pump?
There are a few potential disadvantages to using a ground source heat pump. The initial installation cost can be higher compared to other heating and cooling systems. Additionally, the installation process can be disruptive and may require digging up the ground. However, these upfront costs can be offset by long-term energy savings and potential government incentives.
5. Can a ground source heat pump be used in any climate?
Ground source heat pumps can be used in most climates, but they are more efficient in areas with moderate temperatures. In colder climates, the heat pump may have to work harder to extract heat from the ground, reducing its efficiency. However, in warmer climates, the heat pump can work in reverse to cool the building by transferring heat into the ground. Overall, ground source heat pumps are a versatile and efficient option for heating and cooling in various climates.
  • Mechanical Engineering
  • Thermodynamics
