Ground state energy eigenvalue of particle in 1D potential
In summary, the conversation discusses finding the ground state energy eigenvalue for a system with a particle of mass m moving in a 1D potential V(x) that vanishes at infinity. It is mentioned that the ground state eigenfunction is ψ(x) = A sech(λx), with A and λ being constants. The solution involves solving the Schroedinger equation and evaluating it at infinity to find the potential. The final equation obtained is -λ^2*ħ^2/2m(1-2sech^2(λx))=E-V(x).
upender singh
a particle of mass m moves in 1D potential V(x),which vanishes at infinity.
Ground state eigenfunction is ψ(x) = A sech(λx), A and λ are constants.
find the ground state energy eigenvalue of this system.
ans: -ħ^2*λ^2/2m
<H> =E, H = Hamiltonian.
p= i/ħ∂/∂x[/B]
H = p^2/2m+ V(x)
by normalization, [/B]
|A| = λ
i can take care of p^2/2m but what about V(x)
It should be possible to find it based on the wave function (the Schroedinger equation is satisfied everywhere). There could be some solution that avoids this, not sure if the virial theorem or something similar can be used.
solving the S-equation yields
λ^2*ħ^2/2m(sech^2(λx)-tanh^2(λx))=E-V(x)
or -λ^2ħ^2/2m= E-V(x)
:headbang:
If that is true for every x, evaluate it at x to infinity.
It would need a constant potential, however, which doesn't fit to the given wave function.
I don't understand where your equation comes from. The second derivative is not constant.
sorry,
used the wrong identity
the final equation is,
it is a multiple choice question.
since sech^2(λx) is 0 at infinity, i assume term 1 on lhs represents energy and term 2 represents potential.
That gives a more reasonable potential, and it also gives E-V(x) at x to infinity, where you know the limit of V(x).
upender singh said:
(1-2sech^2(λx))
Could you check this second derivative again ? Perhaps 1 - 2 tanh2 ?
Related to Ground state energy eigenvalue of particle in 1D potential
1. What is the ground state energy eigenvalue?
The ground state energy eigenvalue is the lowest possible energy level that a particle can have in a given potential. It represents the most stable and lowest energy state of the particle.
2. How is the ground state energy eigenvalue calculated?
The ground state energy eigenvalue is calculated by solving the Schrödinger equation for the given 1D potential. This involves finding the wavefunction of the particle and then using it to calculate the energy using the Hamiltonian operator.
3. Why is the ground state energy eigenvalue important?
The ground state energy eigenvalue is important because it provides an understanding of the lowest energy state of a particle in a potential, which is crucial in predicting its behavior and properties. It also serves as a reference point for calculating the energy levels of higher states.
4. Can the ground state energy eigenvalue change?
In most cases, the ground state energy eigenvalue is a constant and does not change. However, it can change if the potential is altered or if external forces are applied to the particle, causing it to move to a different energy level.
5. How does the ground state energy eigenvalue relate to quantum mechanics?
The concept of ground state energy eigenvalue is a fundamental aspect of quantum mechanics, as it helps explain the discrete energy levels of particles in a potential. It also plays a crucial role in understanding various phenomena such as tunneling and the stability of atoms and molecules.
