Ground state energy for exciton in Si
The discussion revolves around estimating the ground state energy for an exciton in silicon (Si), with participants analyzing the calculations and equations involved. The effective mass and dielectric constant values are provided, and the initial calculation yields an implausibly high energy value. Participants debate the interpretation of the variables in the equations, particularly the meaning of "e" and the proper use of constants. The conversation highlights the importance of understanding the symbols in the equations to avoid errors and emphasizes the need for clarity in mathematical expressions. Ultimately, the discussion underscores the challenges faced in accurately applying theoretical physics concepts.
adamaero
Estimate the ground state energy (eV) for an exciton in Si.
εSi = 12
ε = 1.0359×10−10
Effective masses
me* = 0.26me
mh* = 0.36me
effective mass = 0.15me
Values of h
6.626×10−34 J⋅s
4.136×10−15 eV⋅s
Values of ħ Units
1.055×10−34 J⋅s
6.582×10−16 eV⋅s
E1 = me4/(8*h2ε02)
E = m*e4/(8*h2ε2)
0.15(9.11e-31)e^4/[8(6.626e-34)^2(1.0359e-10)^2] =
0.15(9.11e-31)54.59815/[8(6.626e-34)^2(1.0359e-10)^2]
[link to wolfram for this calculation]
= 1.98×1056 J
This seems way too big!
It's even bigger in eV: 1.24×1075
I would really appreciate it if someone could help point out where I went wrong. It seems like most want to beat around the bush...or maybe everyone that's helped me here is just in a rush. That epsilon I'm not 100% sure about either.
What do you understand the term highlighted in red to be?
Wolfram understands to be (Exp[1.0])4. The same understanding applies to all the e's in your expression.
Yes. I don't see any problem with that. The link to Wolfram clearly shows that without the caret operator (^) is needed for an exponential. 10e10 = 100 billion.
adamaero said:
E1 = me4/(8*h2ε02)
What does "e4" mean in your posted equation and how do you implement it?
That's a typo for e4.
And does "e" stand for?
I believe it's the constant: 2.71828
Which constant? What is its value?
Okay, do you actually know the answer to this minor tangent?! If so, why are you beating around the bush?
I understand probing for thinking and such is the main idea of Physics Forums, but this is a mere tangent about an equation.
1.6×10−19
the charge of an electron?
That's what someone else said from a different site.
I don't think so. It's the charge of the electron.
0.15(9.11e-31)1.6e-19/[8(6.626e-34)^2(1.0359e-10)^2] =
5.8×1035 J
or 36×1045 eV
I don't know what the ballpark number should be (so I have no idea if this is near correct).
Maybe so, but it looks like you did not understand what the symbols in the equation stood for and therefore you did not understand the equation and couldn't use it correctly. I wouldn't call that a "mere tangent".
5.8×1035 J
or 36×1045 eV
Where is it that you raise the charge of the electron to the fourth power in this expression?
Ya, I got it. Ate up about 8 hours though.
14.8mJ
It is a mere equation, but I don't have time to explain out why. It should not take an hour to point out that the equation is wrong, and what it actually should be! I mean, a guy from another site is the one who actually helped.
You are welcome.
9K
11K
