Ground state energy of a particle-in-a-box in coordinate scaling
In summary, the conversation discusses the energy spectrum of a particle in a 1D box and how it changes in 3D and n-dimensional boxes of different shapes. It also explores the effect of finite depth in the potential well on the ground state energy, and whether it follows a different scaling law. The conversation suggests that for a finite potential well, the ground state energy decreases faster than ##L^{-2}## as the width of the well increases. The speaker plans to plot the ##E_0 (L)## function in log-log coordinates to confirm this.
hilbert2
Insights Author
605
TL;DR Summary
How does the ground state energy of one particle in n-dimensional box change in uniform coordinate scaling? What happens if the box has a finite depth in potential energy units?
The energy spectrum of a particle in 1D box is known to be
##E_n = \frac{h^2 n^2}{8mL^2}##,
with ##L## the width of the potential well. In 3D, the ground state energy of both cubic and spherical boxes is also proportional to the reciprocal square of the side length or diameter.
Does this apply for an n-dimensional box of any shape, including those that are not simply connected? And if the depth of the potential well is not infinite, does it approach some other scaling law in the limit of small well depth? The first of these claims should probably be true just because of the scaling property of the n-dimensional kinetic energy operator and Laplacian in a uniform coordinate scaling.
Edit: And, if there's a finite potential well of side length ##L##, depth ##V_0##, and ##d## is the approximate distance the particle in the ground state is able to sink inside the potential walls. will the ##E_0## be proportional to ##L^{-2}## if ##L## is made much larger than ##d##? I can solve this numerically myself but it would be interesting to see a source where it has been discussed before.
hilbert2 said:
Summary:: How does the ground state energy of one particle in n-dimensional box change in uniform coordinate scaling? What happens if the box has a finite depth in potential energy units?
In 3D, for rectangle box
[tex]E_{n_x,n_y,n_z}=\frac{h^2}{8m}(\frac{n_x^2}{L_x^2}+\frac{n_y^2}{L_y^2}+\frac{n_z^2}{L_z^2})[/tex]
Yes. that's the spectrum of a 3D parallelepiped potential well, but I was thinking about one of any shape, like elliptical or half-sphere.
Edit: Solving numerically the ground states of several potential wells of same finite but large depth ##V_0##, it seems that the ##E_0## decreases faster than ##L^{-2}## (possibly exponentially) when ##L\rightarrow\infty##.
For 1D well potential Shrodinger equation is written as
[tex]\frac{d^2\psi}{dx^2}+(\epsilon-v)\psi=0[/tex]
where x,##\epsilon##, v are dimensionless parameters, x=X/L, L is width of the well, and ##\epsilon##=E/e, v=V/e
[tex]e=\frac{\hbar^2 }{2mL^2}[/tex]
So limit to infinite well is in exact mathematical sense
[tex]\frac{\hbar^2 }{2mL^2V}\rightarrow +0[/tex]
Wide well or heavy mass does similar effect.
Likes hilbert2
Thanks. I'll have to calculate the ##E_0## of several potential wells of same finite depth ##V_0## but different ##L##. Then I'll plot the ##E_0 (L)## function in log-log coordinates to see how small ##V_0## can be without the result deviating from ##L^{-2}## behavior. Any power law graph looks like a straight line when drawn in double logarithmic coordinates, so that's a way to find out if ##E_0 (L)## decreases exponentially and not like ##L^{-a}## with ##a>0## for some value of ##V_0##.
Related to Ground state energy of a particle-in-a-box in coordinate scaling
1. What is the ground state energy of a particle-in-a-box in coordinate scaling?
The ground state energy of a particle-in-a-box in coordinate scaling refers to the lowest possible energy state that a particle can have when confined to a one-dimensional box and the box's length is scaled by a factor of n. This energy is given by the equation En = (n2h2)/(8mL2), where n is the scaling factor, h is Planck's constant, m is the mass of the particle, and L is the original length of the box.
2. How does the ground state energy change with different scaling factors?
The ground state energy of a particle-in-a-box in coordinate scaling increases as the scaling factor increases. This means that the energy of the particle becomes higher as the box becomes larger. Conversely, as the scaling factor decreases, the energy decreases and the box becomes smaller.
3. What is the significance of the ground state energy in coordinate scaling?
The ground state energy in coordinate scaling is important because it represents the lowest possible energy state that a particle can have in a confined space. This energy level is significant in understanding the behavior of particles in a one-dimensional box and can be used to calculate other energy levels and properties of the system.
4. How does the ground state energy of a particle-in-a-box in coordinate scaling compare to other energy levels?
The ground state energy is the lowest energy level that a particle can have in a one-dimensional box. It is followed by the first excited state, which has an energy of 4 times the ground state energy. This pattern continues for higher energy levels, with each successive energy level being 4 times the previous one.
5. Can the ground state energy of a particle-in-a-box in coordinate scaling be negative?
No, the ground state energy of a particle-in-a-box in coordinate scaling cannot be negative. This is because energy is a positive quantity and the equation for the ground state energy only includes positive values such as h, m, and L. Therefore, the ground state energy will always be positive or zero.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
13K
  • Quantum Physics
