Ground state of Potassium and Hydrogen
In summary, the energy of the least tightly bound electron in potassium (Z=19) is expected to be lower than the energy of the electron in a hydrogen atom in an excited state with the same principal quantum number n. This is due to the screening effect of the other electrons in potassium, which results in a stronger attraction to the nucleus for the 4s electron. In contrast, the hydrogen atom only has one positive charge in the nucleus, resulting in a weaker attraction for the 4s electron. This is supported by the energy equation for hydrogenic atoms, which shows a decrease in energy as the value of n increases.
shyguy79
102
For potassium in ground state configuration (Z=19) how would you expect the energy of the least tightly bound electron to compare with the energy of the electron in hydrogen excited to a state of the same principal quantum number n. Explain your answer.
None
Ok, so in it's ground state in standard notation Potassium 19 is:
K 1s[itex]^{2}[/itex] 2s[itex]^{2}[/itex] 2p[itex]^{6}[/itex] 3s[itex]^{2}[/itex] 3p[itex]^{6}[/itex] 4s[itex]^{1}[/itex]
I'm guessing that the principal quantum number that it's asking for is when n=4 in the hydrogen? If so where do I go from here?
Any help is gratefully received
Is it perhaps that when the quantum number n=4 in the hydrogen atom the eV value ≈ -0.85eV (-13.6ev/4^2)? Because the angular momentum quantum number l = 0 then it has less energy and is closer to the nucleus?
I'm kinda clutching at straws
1s 2 2s 2 2p 6 3s 2 3p 6 electron will screen the nucleus of K, it seems that the 4s electron is attracted by 1 charge(19-18),but it doesn't screen so good,so the 4s electron will see more than 1 charge,for example 2,this situation will increase the attraction force to the 4s electron resulting in the decreasing of the energy.In contrast to hydrogen atom ,the nucleus is just 1 charge.so the energy of 4s electron will lower than that of the 4s electron of hydrogen.
The ground state configuration of potassium has one electron in its outermost shell, in the 4s orbital. This electron is less tightly bound compared to the electron in hydrogen in the same principal quantum number n=4. This is because potassium has a higher nuclear charge (Z=19) compared to hydrogen (Z=1), which results in a stronger attraction between the nucleus and the outer electron. This stronger attraction leads to a lower energy for the outer electron in potassium compared to the outer electron in hydrogen.
In addition, the outer electron in potassium also experiences shielding from the inner electrons, which reduces its effective nuclear charge and further lowers its energy. On the other hand, the outer electron in hydrogen does not experience any shielding and thus has a higher energy compared to the outer electron in potassium.
Overall, the outer electron in potassium is expected to have a lower energy compared to the outer electron in hydrogen in the same principal quantum number n=4.
Related to Ground state of Potassium and Hydrogen
What is the ground state of Potassium?
The ground state of Potassium is the lowest energy state that the atom can exist in. It is when all of its electrons are in their lowest possible energy levels.
What is the ground state of Hydrogen?
The ground state of Hydrogen is the lowest energy state that the atom can exist in. It is when its only electron is in the 1s orbital, the lowest energy orbital.
How does the ground state of an atom affect its reactivity?
The ground state of an atom can affect its reactivity because it determines the arrangement and stability of its electrons. Atoms in their ground state are more stable and less reactive than atoms in excited states.
Why are the ground states of Potassium and Hydrogen important to study?
The ground states of Potassium and Hydrogen are important to study because they provide a foundation for understanding the electronic structure and behavior of atoms. They also play important roles in many chemical reactions and processes.
How can the ground state of an atom be changed?
The ground state of an atom can be changed by adding or removing energy from the atom. This can be done through various methods, such as heating, cooling, or exposure to electromagnetic radiation.
