Ground state wavefunction real?
In summary: Hamiltonian is real. The ground state wavefunction is always real if the Hamiltonian has real coefficients and no first order spatial derivatives. This means that for any eigenfunction psi of H to the eigenvalue E, Re psi and Im psi have the same property and are real. In particular, if the ground state is nondegenerate, Re psi and I am psi must be proportional, which means that the ground state is a constant multiple of a real function. However, why should there be no first order derivatives? Why should there be no first order derivatives?For simplicity, and since this holds for many concrete Hamiltonians, everything holds
krishna mohan
117
Hi..
In a textbook, the ground-state wavefunction for any general Hamiltonian was under consideration. Then, a statement was made that this wave function is real since it is the ground state.
Is it true that one can always choose the ground state wave function to be real?
I understand that absolute phases don't matter in quantum physics, but relative phases do. Is it that one can choose the ground state wavefunction to be real and, as a consequence, lose the freedom of choosing the phases for the other wavefunctions?
krishna mohan said:
Hi..
This is always the case if the Hamiltonian has real coefficients and no first order spatial derivatives. In this case, for any eigenfunction psi of H to the eigenvalue E, Re psi and
I understand the rest of it...
But why should there be no first order derivatives?
For simplicity, and since this holds for many concrete Hamiltonians.
The more general statement is that everything holds when the Hamiltonian, expressed in terms of the quantum position and momentum operators, has only real coefficients.
I take it you mean the solution to the time independent schordinger equation(TISE). If that is the case, then not just the ground state, any solution can be taken to be real. If psi is a solution of the TISE, then so is its complex conjugate psi* (do it and check it, this is so because the potential is taken to bereal). Since the differential equation is linear, you can now take any linear combination of psi and psi* as it will also be a solution to TISE.
So you make your life easier by choosing psi+psi* and choosing a real wavefunction.
FAQ: Ground state wavefunction real?
What is the ground state wavefunction real?
The ground state wavefunction real is a mathematical representation of the most stable energy state of a physical system. It describes the distribution of particles or waves in a system at its lowest energy level.
How is the ground state wavefunction real determined?
The ground state wavefunction real is determined through quantum mechanical calculations and observations. It involves solving the Schrödinger equation, which describes the behavior of particles at the subatomic level, to find the lowest energy state of a system.
What does the ground state wavefunction real tell us about a system?
The ground state wavefunction real provides information about the spatial distribution of particles or waves in a system at its lowest energy level. It also helps us understand the stability and behavior of the system, as well as the probability of finding a particle at a particular location.
Is the ground state wavefunction real the same for all systems?
No, the ground state wavefunction real is unique for each system. It depends on factors such as the number of particles, their interactions, and external conditions. However, certain systems may have similar ground state wavefunctions due to similarities in their properties.
What are some applications of the ground state wavefunction real?
The ground state wavefunction real is used in various fields such as quantum mechanics, chemistry, and material science. It helps in understanding the properties and behavior of atoms, molecules, and solids. It also plays a crucial role in the development of technologies such as lasers, transistors, and superconductors.
