MHB Group Algebra - Cohn page 55 - SIMPLE CLARIFICATION
  • Thread starter Thread starter Math Amateur
    Algebra Group
The discussion focuses on the concept of group algebras as presented in P. M. Cohn's "Introduction to Ring Theory." It clarifies that for a finite group G, the elements of the group algebra kG are expressed as finite sums of the form ∑ α_g g, where α_g are coefficients from a field k. The multiplication of two elements in kG follows a specific rule that resembles polynomial multiplication, ensuring that G serves as a k-basis for the algebra. The participants also explore the implications of this structure, including the linear independence of G and its role as a subgroup of the units in kG. Overall, the thread emphasizes understanding the algebraic properties and operations within group algebras.
Math Amateur
MHB
I am reading "Introduction to Ring Theory" by P. M. Cohn (Springer Undergraduate Mathematics Series)
In Chapter 2: Linear Algebras and Artinian Rings we read the following on page 55:https://www.physicsforums.com/attachments/3142I am trying to get an idea of what Cohn says and means by a group algebra …
Take a case where $$G$$ is finite and has order $$|G| = n$$
Then according to Cohn the elements of the group algebra, $$kG$$, are the finite sums $$\sum \alpha_g g$$
So, two specific elements could be as follows:
$$\sum \alpha_g g$$
$$ = \alpha_{g_1} g_1 +\alpha_{g_2} g_2 + \ … \ … \ + \alpha_{g_n} g_n $$
and
$$\sum \beta_h h$$
$$ = \beta_{h_1} h_1 + \beta_{h_2} h_2 + \ … \ … \ + \beta_{h_n} h_n $$
and the product would be as follows:
$$ ( \sum \alpha_g g ) ( \sum \beta_h h ) = \alpha_{g_1} \beta_{h_1} g_1 h_1 + \alpha_{g_2} \beta_{h_2} g_2 h_2 + \ … \ … \ + \alpha_{g_n} \beta_{h_n} g_n h_n $$
Now is the above interpretation of the elements and multiplication (dot product?) correct?
Note that in the above text, Cohn writes:
" … … Put more simply, kG has G as a k-basis … …"
What does Cohn mean by a "k-basis"?
Peter
***EDIT*** Apologies to MHB members for the previous version of their post … it had unreadable elements due to an editor problem … problem was resolved thanks to Mark … my thanks to Mark.
$$\sum \alpha_g g$$
$$ \alpha_{g_1} g_1 +\alpha_{g_2} g_2 + \ … \ … \ + \alpha_{g_n} g_n $$
and
$$\sum \beta_h h$$
$$( \sum \alpha_g g ) ( \sum \beta_h h ) = \alpha_{g_1} \beta_{h_1} g_1 h_1 + \alpha_{g_2} \beta_{h_2} g_2 h_2 + \ … \ … \ + \alpha_{g_n} \beta_{h_n} g_n h_n $$
Peter
Given any group $G$ and any field $k$, we can form a $\Bbb k$-algebra such that the elements of $G$ together form a basis. To do so, define a set $\Bbb kG$ to be the set of all formal sums $$\sum_{g\in G} k_g\, g$$,where the $k_g \in \Bbb k$. The zero in $\Bbb kG$ is defined to be the sum $$\sum_{g\in G} 0g$$. Then $\Bbb kG$ is a vector space over $\Bbb k$. By construction, $G$ spans $\Bbb kG$. Further, $G$ is a linearly independent set in $\Bbb kG$. For if $$\sum_{g\in G} k_g\, g = 0$$ is a linear relation in $\Bbb kG$, then $k_g = 0$ for all $g\in G$, again by construction. So $G$ is a $\Bbb k$-basis for $\Bbb kG$, that is, $G$ is a basis for $\Bbb kG$ as a vector space over $\Bbb k$.
Define a multiplication in $kG$ by
$\displaystyle \sum_{g\in G} k_g\, g \cdot \sum_{g\in G} j_g\, g = \sum_{u\in G} \left(\sum_{gh = u} k_g j_h\right) u$.
With this multiplication, $\alpha(xy) = (\alpha x)y = x(\alpha y)$ for all $x, y\in \Bbb kG$ and $\alpha\in \Bbb k$. It follows that $\Bbb kG$ is a $\Bbb k$-algebra, which Cohn calls the group algebra of $G$ over $\Bbb k$.
$$\sum \alpha_g g$$
and
$$\sum \beta_h h$$
Peter
Let's do an easy example, say:
$G = \{e,a,a^2\}$, a cyclic group of order 3, and $k = \Bbb Q$.
So a typical element of $\Bbb Q[G]$ looks like this:
$q_1e + q_2a + q_3a^2$ where $q_1,q_2,q_3 \in \Bbb Q$.
Let's multiply two such elements together:
$(p_1e + p_2a + p_2a^2)(q_1e + q_2a + q_3a^2)$
$ = p_1q_1(ee) + p_1q_2(ea) + p_1q_3(ea^2) + p_2q_1(ae) + p_2q_2(aa) + p_2q_3(aa^2) + p_3q_1(a^2e) + p_3q_2(a^2a) + p_3q_3(a^2a^2)$
$= (p_1q_1 + p_2q_3 + p_3q_2)e + (p_1q_2 + p_2q_1 + p_3q_3)a + (p_1q_3 + p_2q_2 + p_3q_1)a^2$
(note the similarity with polynomial multiplication, here).
Note that $1e\ (= 1e + 0a + 0a^2)$ serves as a ring identity.
Basically, we use the distributive rule to "expand everything out" and then "collect like terms" after we evaluate the group products $g_ig_j$ (the "sigma" summation notation is more compact, but obscures what is actually happening-one must pay careful attention to the indices).
Sometimes, this product is written:
$\displaystyle \left( \sum_i a_ig_i\right)\left(\sum_j b_j g_j\right) = \sum_{g_ig_j = g_k} a_ib_jg_k$
One can form a similar notion of a "monoid-ring", $k[M]$, in which case we have $k[x] \cong k[\Bbb N]$
(the corresponding notion for $k[\Bbb Z]$ would be the set of expressions:
$\dfrac{a_{-n}}{x^n} +\cdots + \dfrac{a_{-2}}{x^2} + \dfrac{a_{-1}}{x} + a_0 + a_1x + a_2x^2 + \cdots + a_mx^m$
that is to say, a finite Laurent series, or rational function in $x$ over $k$).
For the $\Bbb Q$-algebra $\Bbb Q[G]$ I have outlined above, we have the following multiplicative constants:
$\gamma_{111} = 1$
$\gamma_{112} = 0$
$\gamma_{113} = 0$
$\gamma_{121} = 0$
$\gamma_{122} = 1$
$\gamma_{123} = 0$
$\gamma_{131} = 0$
$\gamma_{132} = 0$
$\gamma_{133} = 1$
$\gamma_{221} = 0$
$\gamma_{222} = 0$
$\gamma_{223} = 1$
$\gamma_{231} = 1$
$\gamma_{232} = 0$
$\gamma_{233} = 0$
$\gamma_{331} = 0$
$\gamma_{332} = 1$
$\gamma_{333} = 0$
and the ones not listed follow by commutativity of $G$.
It should be clear that the group $G$ itself is a subgroup of the group of units of $k[G]$.
$\gamma_{111} = 1$
$\gamma_{112} = 0$
$\gamma_{113} = 0$
$\gamma_{121} = 0$
$\gamma_{122} = 1$
$\gamma_{123} = 0$
$\gamma_{131} = 0$
$\gamma_{132} = 0$
$\gamma_{133} = 1$
$\gamma_{221} = 0$
$\gamma_{222} = 0$
$\gamma_{223} = 1$
$\gamma_{231} = 1$
$\gamma_{232} = 0$
$\gamma_{233} = 0$
$\gamma_{331} = 0$
$\gamma_{332} = 1$
$\gamma_{333} = 0$
Thanks Deveno … these examples provide wonderful learning experiences … wish the texts had more like these examples ...
Peter
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
29K
