I Group like operations that are not associative
pervect
Staff Emeritus
Insights Author
A group can be defined by the following three properties. (Source: wikipedia)
In mathematics, a group is a set and an operation that combines any two elements of the set to produce a third element of the set, in such a way that the operation is associative, an identity element exists and every element has an inverse.
Is there any example of an operation that fails the associativity test, but meets the other two tests? I'll refer to this hypothetical entity as an almost-group for the purposes of this post lacking any knowledge of a better name. While my specific motivation is in Lie groups, an example of such an operation that is a finite almost-group but not associative would be helpful.
The motivating question is just how intuitively obvious is it that coordinate transformations must form a Lie group. Intuitively, it's obvious that the identity transformation must exist, and the requirement that coordinate transformations be invertible also seems intuitive, but it's less intuitive why a coordinate transformation absolutely must be associative. That said, I can't think of any counterexamples that are not associative. I have some vague intuitive ideas why a coordinate transformation should be associative, but they're a bit fuzzy and I couldn't express them well.
While the motivational idea is about Lie "almost-groups", a discreete version would also be helpful to guide my intuition.
Note: an answer at the A level is acceptable, but I'd prefer that it be kept to the I level if at all possible. If there is an A-level answer readily available and it'd be too much work to dumb it down to the I-level, it'd be better to have the A-level answer than none at all.
Say hello to the octonions:
https://en.wikipedia.org/wiki/Octonion
Likes The Bill and topsquark
pervect said:
... but it's less intuitive why a coordinate transformation absolutely must be associative. That said, I can't think of any counterexamples that are not associative. I have some vague intuitive ideas why a coordinate transformation should be associative, but they're a bit fuzzy and I couldn't express them well.
For any coordinate transformation, the "multiplication" is function composition ##(f \circ g)(\textbf{x}) = f(g(\textbf{x}))##. The associative law ##(f \circ g) \circ h = f \circ (g \circ h) ## follows by just plugging in the definition.
Likes Stephen Tashi
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
