MHB Group of units - Rotman - page 36 - Proposition 1.52
  • Thread starter Thread starter Math Amateur
    Group Units
The discussion centers on understanding Proposition 1.52 from Joseph Rotman's "Advanced Modern Algebra," specifically the proof that each element r in U(ℤ/mℤ) has an inverse. Participants express confusion over Rotman's argument regarding the conditions under which an element is a unit, particularly the implications of the gcd conditions. Clarifications are provided, emphasizing that if gcd(k, m) = 1, then there exist integers a and b such that ak + bm = 1, demonstrating that [a] is the inverse of [k]. An example using specific values for k and m illustrates the process of finding inverses and reinforces the closure property of the unit group. Overall, the discussion aims to clarify the proof's logic and enhance understanding of the concepts involved.
Math Amateur
MHB
I am reading Joseph Rotman's book Advanced Modern Algebra.
I need help in fully understanding the proof of Proposition 1.52 on page 36.
Proposition 1.52 and its proof reads as follows:
The part of the proof on which I need help/clarification is Rotman's argument where he establishes that each $$ r \in U( \mathbb{I}_m ) $$ has an inverse in $$ U( \mathbb{I}_m ) $$.
As can be seen in the text above Rotman's argument (which I must say confuses me) reads as follows:
"If $$ (a,m) = 1 $$ then $$ [a][x] = 1 $$ can be solved for x in $$ \mathbb{I}_m $$. Now (x,m) = 1 for rx + sm = 1 for some integer s, and so (x,m) = 1. Hence $$ [x] \in U( \mathbb{I}_m ) $$, and so each $$ r \in U( \mathbb{I}_m ) $$ has an inverse in $$ U( \mathbb{I}_m ) $$."
I confess I cannot follow Rotman's argument above! (maybe MHB members will find it clearer than I do?)
Can someone please provide a clear and rigorous restatement of Rotman's argument regarding inverses in $$ U( \mathbb{I}_m ) $$.
Particular points of confusion are as follows:
1. Rotman writes: "If $$ (a,m) = 1 $$ then $$ [a][x] = 1 $$ can be solved for x in $$ \mathbb{I}_m $$." - I cannot see exactly why this follows:
2. Rotman writes: "Now (x,m) = 1 for rx + sm = 1 for some integer s, and so (x,m) = 1." - I do not follow this statement at all: indeed I think it may be badly expressed whatever he means ... ...
3. I do not follow the rest of his statements - probably because I do not follow 1 and 2 above.
Help and clarification would be appreciated
Peter
Note that Rotman uses the symbol $$\mathbb{I}_m$$ for $$ \mathbb{Z}/ m \mathbb{Z} $$.
Ok, what Rotman is saying is:
$[k] \in \Bbb Z_m$ is a unit if and only if $\text{gcd}(k,m) = 1$.
$(\impliedby)$: Suppose $\text{gcd}(k,m) = 1$. Using the (extended) Euclidean algorithm for finding the gcd, we can find integers $a,b$ such that:
$ak + bm = 1$ (Bezout's Identity).
If we reduce this equation mod $m$, we get:
$[a][k] + [0] = [a][k] + [0] = [a][k] = [1]$.
Evidently, then, $[a]$ is an inverse for $[k]$ in $\Bbb Z_m$.
$(\implies)$: On the other hand, suppose $[k]$ is a unit. This means that for some $ \in \Bbb Z_m$ we have:
$[k] = [1]$.
This means that:
$(u + am)(k + bm) = 1 + cm$, for some integers $a,b,c$. It then follows that:
$uk + (ak + bu + abm - c)m = 1$, which shows that $\text{gcd}(k,m) = 1$.
I will show you how we actually DO this, for a specific $k$ and $m$. Suppose $m = 24$ and $k = 7$. We want to show $[7]$ is a unit. To do so, we need to find its inverse. Note that $\text{gcd}(7,24) = 1$, so we ought to be able to do this.
What we want to do, is find $a,b$ so that $7a + 24b = 1$. So this is what we do:
24 = 3*7 + 3
7 = 3*2 + 1
therefore:
1 = 7 - 6 = 7 - 3*2 = 7 - (24 - 3*7)*2 = 7 - 2*24 + 6*7 = 7*7 + (-2)*24
so $a = 7$ and $b = -2$. We don't need $b$, we just want $a$, and since $0 \leq 7< 24$, we don't even need to reduce.
And indeed: $[7]*[7] = [49] = [48] + [1] = [2*24] + [1] = [2][24] + [1] = [2][0] + [1] = [0] + [1] = [1]$.
Now Rotman shows closure of $U(\Bbb Z_m)$ by showing if $\text{gcd}(k,m) = 1$ and $\text{gcd}(k',m) = 1$, then:
$\text{gcd}(kk',m) = 1$.
but I find it easier to note that if:
$[a][k] = [1]$ and $[a'][k'] = [1]$, then: $[aa'][k][k'] = [aa'kk'] = [(ak)(a'k')] = [ak][a'k'] = ([a][k])([a'][k']) = [1][1] = [1]$
so that evidently $[aa']$ is an inverse for $[k][k']$, so the product of two units is again a unit.
Again, let's use $m = 24$ as an example. Clearly $[5]$ is also a unit. Note that $[5]$ is its own inverse:
$[5][5] = [25] = [1] + [24] = [1] + [0] = [1]$.
What we have done above says that $[5][7] = [35] = [11]$ is also a unit, with inverse:
$[5*7] = [35] = [11]$.
We verify:
$[11][11] = [121] = [1] + [120] = [1] + [5][24] = [1] + [5][0] = [1] + [0] = [1]$.
$[k] = [1]$.
This means that:
24 = 3*7 + 3
7 = 3*2 + 1
therefore:
We verify:
Thanks Deveno ... just skimmed through your post and am now working through it in detail to ensure I fully understand what you have said ...
From my brief read, your post is extremely clear and helpful (especially since it includes a concrete example!) ... ... so if you ever write a book, then please let me know ... it would likely be so much more easy to follow than the extant texts ...
Thanks again,
Peter
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 26 ·
