MHB Group Velocity and Phase Velocity
The discussion focuses on deriving expressions for group velocity and phase velocity in uniaxial crystals, specifically for extraordinary waves. Participants seek clarification on how to approach Problem 4.4, which involves calculating the group velocity as a function of the polar angle and determining the angle between phase and group velocities. The need for additional information and definitions regarding phase and group velocity is emphasized, as well as the relevance of previous homework problems for context. The conversation highlights the complexity of the topic and the necessity for clear definitions to facilitate understanding.
Joystar77
I have no idea how to do this or where to start. Can someone please help me?
Problem 4.4- Suppose n o and n e are given. In (a) you only need to find the magnitude of the group velocity. Problem #2 in HW 10 may be helpful. You can also directly use the definition of group velocity, i.e., v g = triangle k w (k), taking into account the equation of the wave normal surface.
4.4- Group Velocity and Phase Velocity
a.) Derive an expression for the group velocity of the extraordinary wave in a uniaxial crystal as a function of the polar angle 0 of the propagation vector.
b.) Derive an expression for the angle a between the phase velocity and the group velocity. This angle is also the angle between the field vectors E and D.
c.) Show that a = 0 when 0 = 0, ½ pi. Find the angle at which a is maximized and obtain an expression for a max. Calculate this angle a max for quartz with n o = 1.554, n e = 1.553.
d.) Show that for no or ne, the maximum angular separation a max occurs at 0 = 45 degrees; show that a max is proportional to [ n o – n e].
Mathematics news on Phys.org
I'm afraid no one is going to be able to help you without more information. Certainly no one here knows what "problem #2 in HW 10" is!
What are you using as the definitions of "phase velocity" and "group velocity"?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
