Group velocity of Quantum state
In summary, the problem is to find the group velocity and probability associated with a state described by the time dependent representation of a wave packet. The group velocity is found to be vg = (dw/dk) at w = w0 and the probability at a specific position and time is given by |\Psi(x-vgt,0)|^2. The meaning of these results is that the wave packet travels with a constant velocity and maintains the same probability density. The exact meaning of the probability per unit length is unclear.
Relativeee
Ok hello, The problem is there is a system in the state characterized by
[tex]\Psi[/tex](x,t) = [tex]\int[/tex] dk e^(ikx)e^(-iwt)f(k), which is the time dependent representation of a wave packet, where individual waves travel with velocity
vp = w/k and f(k) = (2*[tex]\alpha[/tex]/[tex]\pi[/tex])^(1/4)e^(-[tex]\alpha[/tex]*k^2). The problem is to find the group velocity(associated with the state) along with the probability for measuring the particle at time t=t0>0 at position x=x0>0 and also probability per unit length at same position. Also what exactly is the meaning of these results?
Ok so the first part, the idea in the book was if f(k) has a peak at k = k0 and w is a function of k then there can be an expansion of w around the point k = k0
w = w(k) = w0 + (dw/dk)(k-k0) = w0 + vg(k-k0), where vg = (dw/dk) at w = w0
Ok now to show that vg is group velocity, we can note that since dominant contributions of [tex]\Psi[/tex](x,t) come from region where k = k0 the above expansion can be kept at first order in (k-k0) and so from the integral we can write kx - wt = kx - [w0 +vg(k-k0)]t
and therefore the integral can be written as
[tex]\Psi[/tex](x,t) =e^[i(k0vg-w0)t] [tex]\int[/tex] dk e^[ik(x-vgt)]f(k)
[tex]\Psi[/tex](x,t) =e^[i(k0vg-w0)t][tex]\Psi[/tex](x-vgt,0) so we note that the packet travels as a whole velocity vg that maintains the same probability density and therefore we can call vg the group velocity.
So that was i was thinking they were asking for the first part. For finding the probability at x = x0 > 0 and t = t0> 0 is it enough to say that the probability is
|[tex]\Psi[/tex](x0-vgt0,0)|^2? I am not quite sure on the probability per unit length or The exact meaning of these results. If anyone could give some insight that would be great thanks alot
Anyone has a solution?
Related to Group velocity of Quantum state
1. What is the group velocity of a quantum state?
The group velocity of a quantum state refers to the speed at which the overall probability of finding a particle in a particular state moves in space over time. It is a concept used in quantum mechanics to describe the behavior of particles and their states.
2. How is the group velocity different from the phase velocity?
The group velocity and phase velocity are two different ways of measuring the speed of a particle. The group velocity takes into account the overall probability of finding a particle in a particular state, while the phase velocity only considers the rate at which the phase of the wave function changes.
3. Can the group velocity of a quantum state exceed the speed of light?
No, the group velocity of a quantum state cannot exceed the speed of light. This is because the group velocity is determined by the properties of the wave function, which cannot travel faster than the speed of light due to the principles of relativity.
4. How does the group velocity change in different quantum systems?
The group velocity of a quantum state can vary in different quantum systems depending on the properties of the particles and their interactions. In some systems, the group velocity may remain constant, while in others it may change over time due to external influences.
5. What is the significance of the group velocity in quantum mechanics?
The group velocity is an important concept in quantum mechanics as it helps us understand the behavior of particles and their states. It is used in various quantum theories and experiments to make predictions and study the properties of quantum systems.
