Grouping terms to start factoring.
In summary: In this case, we found a common ratio of $-2:4:1$ in the first group, and then $1:8:-3$ in the factored form.
bergausstein
191
how would i go about properly grouping terms to start my factoring?
1. $12x^2y^3-24y^3z-6x^6+30y^4-15x^4y+4x^2y+12x^4z+10y^2-8yz$
thanks!
Mathematics news on Phys.org
I suspect there is a small typo in the problem, because it almost factors, but not quite. I can get it to:
\(\displaystyle (5y-4z)\left(2y\left(3y^2+1 \right)-3x^4 \right)+2x^2\left(2y\left(3y+1 \right)-3x^4 \right)\)
yes, the first term is $12x^2y^3$
$(5y-4z+2x^2)(6y^3-3x^4+2y)$ this should be the completely factored form.
but how did you quickly determine the proper grouping is this $\displaystyle (5y-4z)\left(2y\left(3y^2+1 \right)-3x^4 \right)+2x^2\left(2y\left(3y+1 \right)-3x^4 \right)$
can you show me the steps how did you arrive at this.
Okay, so we have:
\(\displaystyle 12x^2y^3-24y^3z-6x^6+30y^4-15x^4y+4x^2y+12x^4z+10y^2-8yz\)
If we observe that we have 3 groups of 3 coefficients in the ratio $2:5:-4$, we can group as follows:
\(\displaystyle \left(12x^2y^3+30y^4-24y^3z \right)+\left(4x^2y+10y^2-8yz \right)+\left(-6x^6-15x^4y+12x^4z \right)\)
Next, pull the greater factor common to each term in each group:
\(\displaystyle 6y^3\left(2x^2+5y-4z \right)+2y\left(2x^2+5y-4z \right)-3x^4\left(2x^2+5y-4z \right)\)
And now we see we have a factor common to all 3 groups:
\(\displaystyle \left(2x^2+5y-4z \right)\left(6y^3+2y-3x^4 \right)\)
okay, i have another problem similar to problem above.
$4xy+32x^3-12x^2+y^3+8x^2y^2-3xy^2-3xy^2-2x^2y-16x^4+6x^3$
following your method i got
$(4xy+32x^3-12x^2)+(8x^2y^2-16x^4+6x^3)+(y^3-3xy^2-2x^2y)$
$4x(y+8x^2-3x)+2x^2(4y^2-8x^2+3x)+y(y^2-3xy-2x^2)$
i can't see a common factor to each term. can you tell why is that?
Okay, we have:
\(\displaystyle 4xy+32x^3-12x^2+y^3+8x^2y^2-3xy^2-2x^2y-16x^4+6x^3\)
I see a common ratio of $-2:4:1$:
\(\displaystyle \left(-2x^2y+4xy+y^3 \right)-\left(-6x^3+12x^2+3xy^2\right)+\left(-16x^4+32x^3+8x^2y^2 \right)\)
I will let you continue...
this is what i have
$(4x+y^2-2x^2)(y+8x^2-3x)$
but how do you determine that ratio thing?
bergausstein said:
this is what i have
Looks good.
You just have to look for it...the more experience you have, the better you will be at more quickly spotting it, it it exists.
uhm it sounds difficult. but will that method always works in this type of problem.
If it is factorable it will work. I would hesitate to say there is an "always will work" method when it comes to factoring. Factoring is a skill that requires a great deal of trial and error at times, but as you develop experience, you become better at it.
Since there were 9 terms in the polynomial, then we should look at making 3 groups of 3 terms. Then you look for a common ratio among the numeric coefficients. I noticed a $4:1:-2$ ratio, but as we see from the factored form, there is also $1:8:-3$ ratio too.
This worked for this polynomial. Other polynomials might require other techniques. :D
why do you call it common ratio?
Because it is a ratio common to all groups.
FAQ: Grouping terms to start factoring.
What is the purpose of grouping terms to start factoring?
Grouping terms is a common technique used in algebra to simplify and solve equations. In factoring, grouping helps to identify common factors and make the factoring process more efficient.
How do you identify terms that can be grouped?
To identify terms that can be grouped, look for common factors among the terms. These factors can be numerical coefficients, variables, or both. Grouping can also be done by rearranging the terms in a way that makes it easier to identify common factors.
Can grouping be used in any type of factoring?
Yes, grouping can be used in both simple and complex factoring. It is particularly useful in factoring expressions with four or more terms.
Is there a specific order in which terms should be grouped?
No, there is no specific order in which terms should be grouped. However, it is important to group terms in a way that makes it easier to identify common factors and simplify the expression.
Are there any limitations to using grouping in factoring?
Grouping can only be used when there are common factors among the terms. If there are no common factors, grouping cannot be applied. Additionally, grouping may not always result in a fully factored expression, but it can still simplify the equation to some extent.
