Lepros
- 3
If f(x) if big-theta of g(x), is it also always the case then that g(x) is big-theta of f(x)?
Evgeny.Makarov said:Affirmative. (The forum requires a 5-character minimum reply, so I could not just answer "yes".)
Why ?Evgeny.Makarov said:Affirmative. (The forum requires a 5-character minimum reply, so I could not just answer "yes".)
Sorry, I was considering big O and not big theta :( I thought there were the same :(Evgeny.Makarov said:-
Big Theta is a mathematical notation used to describe the growth rate of a function. It represents the set of all functions that grow at the same rate as the given function, up to a constant factor.
Big Theta is similar to Big O and Big Omega in that they all represent the growth rate of a function. However, Big Theta provides a tighter bound on the growth rate, as it considers both the upper and lower bounds of the function.
To determine the Big Theta of a function, you must find two constant values, c1 and c2, such that the function is sandwiched between c1*g(n) and c2*g(n) for all values of n. This means that the function grows at the same rate as g(n), up to a constant factor.
No, a function can only have one Big Theta value. This is because Big Theta represents the growth rate of a function as n approaches infinity, and a function can only have one limiting behavior as n gets larger.
In algorithm analysis, Big Theta is used to determine the efficiency of an algorithm in terms of its time or space complexity. It helps to compare different algorithms and choose the most efficient one for a given problem.
