MHB Growth proportional to square root of worth.
ineedhelpnow
Hi! :o I'm stuck :confused:
I was thinking I need to use the equation $f=kw^2$ but I'm really not sure.
So that first sentence there: "A firm has a fortune that grows at a yearly rate proportional to the square root of its worth." Can you translate that sentence into a differential equation?
Suppose the firm's fortune is given by $$n(w)$$, the firm's worth is $$w$$ and the time taken is $$t$$. Can you set up an differential equation to show the firm's fortune in terms of worth at a given time
$$\dfrac{dn}{dt} \propto \sqrt{w} \ \rightarrow \dfrac{dn}{dt} = k \sqrt{w}$$ where $$k$$ is some constant
edit: making it clear that $$n$$ is a function of $$w$$
Sorry for the late response. The assignment was due and I got really distracted after but I'd still like to work through the problem to see how it's done.
@Ackbach No, I don't. Well until SuperSonic showed it. :p I still don't understand where to go from there. I'm super lost.
@SuperSonic Thank you :D
I would let time $t=0$ be at 1/2 year ago, and let $W$ be measured in millions of dollars. Then I would state the IVP:
$$\frac{dW}{dt}=k\sqrt{W}$$ where $$W(0)=1,\,W\left(\frac{1}{2}\right)=4$$
Separating variables and using the boundaries as limits, we have:
$$\int_1^{W} u^{-\frac{1}{2}}\,du=k\int_0^t\,dv$$
$$2\left[u^{\frac{1}{2}}\right]_1^{W}=k[v]_0^t$$
$$2\left(\sqrt{W}-1\right)=kt$$
Since $k$ is a constant, we can divide through by 2 and still have a constant:
$$\sqrt{W}-1=kt$$
$$W(t)=(kt+1)^2$$
Now, using the second point to determine $k$
$$\left(\frac{k}{2}+1\right)^2=4$$
$$\frac{k}{2}+1=2$$
$$k=2$$
Hence:
$$W(t)=(2t+1)^2$$
