MHB Guessing a three digit pin code from an 8 key keypad
  • Thread starter Thread starter jridgeman99
    Code Pin
The discussion centers on calculating the probability of correctly guessing a three-digit PIN code from an 8-key keypad, allowing for repetition of digits. Participants clarify that this scenario involves permutations since the order of digits matters, making 123 different from 321. The fundamental counting principle is applied to determine the total number of possible PIN combinations. Given the parameters, there are 512 possible PIN codes (8^3). The probability of a correct guess on the first try is therefore 1 in 512.
jridgeman99
Hello, the problem is as follows. I'm not sure if it is a permutation or combination problem. It says if a thief steals and ATM card and must randomly guess the correct three digit pin code from an 8 key keypad. Repetition of digits is allowed. What is the probability of a correct guess on the first try?
Mathematics news on Phys.org
How many PIN codes are possible...can you apply the fundamental counting principle to answer this question?
I'll just add on to Mark's comment that PINs are order-sensitive. 123 is not the same as 321.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
