Guide to NMR spectra notations/nomenclature needed
In summary, the conversation discusses proton (1H) NMR spectra using chloroform (CDCl3) solvent and presents them in standard format with information on chemical shifts, number of equivalent hydrogen atoms, splitting pattern, and identified functional groups. It also includes a request for a reference on this notation scheme in English and French. Further information on interpreting NMR chemical shifts can be found in the provided link.~~~
VDX
Hello everyone. In the literature I come across spectra data as in the examples below:
English example:
1H-NMR (CDCl3) δ: 1.09 (3H, t, CH3), 3.77 (3H, s, OCH3), 3.97-4.28 (2H, m, CH2), 4.28 (1H, s, CH) 6.41 (2H, t, pyrrole-H), 6.78 (2H, t, pyrrole-H), 7.13-7.21 (5H, m, ArH), 8.53 (1H, d, J=5.2Hz, ArH), 8.69(1H, s, ArH); MS(m/z): 368(M+).
French example:
'H RMN (CDC13) 8 : 1,47 (s, 9H) ; 2,93 (dd, 1H) ; 3,07 (dd, 1H) ; 3,95 (d, 1H) ; 4,27 (ls, 1H) ; 4,34 (d, 1H) ; 5,64 (LD, 1H) ; 7,00 (M, 2H) ; 7,18 (td, 1H) ; 7,41 (d, 1H) HPLC (Chiracel OD, HEXANE/ISOPROPANOL (92 : 8), 0,5 ML/MIN) : composé (Xa-1), temps de rétention = 12,71 min ; composé (Xa-2), temps de RéTENTION = 14, 05 min ; rapport des AUC (Xa-1)/ (Xa-2) = 98 : 2.
Would someone be so kind as to point me to a reference for the above notation scheme in English (and if possible in French)?
Thanks, and great work with this forum! :wink:
English example:
French example:
The above are Proton (1H) NMR spectra, using chloroform (CDCl3) solvent, presented in standard format, indicating the Chemical Shifts (in ppm), the number of structurally equiv H atoms producing the shift ("nH"), the splitting pattern ("s"=singlet, "d"=doublet, "t"=triplet, "m"=multiplet, etc.) caused by spin coupled adjacent non-equiv H atoms, and the identified Functional Group. Examples:
"1.09 (3H, t, CH3)" ----> Chem Shift 1.09 ppm, 3 H atoms (struct equiv), triplet (3 lines) from adjacent spin-coupled H, and identified CH3 functional group.
"3.97-4.28 (2H, m, CH2)" ----> Chem Shift spread from 3.97-4.28 ppm, 2 H atoms (struct equiv), multiple lines from adjacent spin-coupled H, and identified CH2 functional group.
More info on interpreting NMR chemical shifts can be found here:
http://wwwchem.uwimona.edu.jm:1104/spectra/nmrintro.html
Hello! Thank you for your question. The notation used in NMR spectra is known as the chemical shift notation and it is used to describe the position of peaks in the spectrum. The chemical shift is measured in parts per million (ppm) and it indicates the relative position of the peak with respect to a reference compound, usually tetramethylsilane (TMS). The chemical shift is influenced by the electron density around the nucleus, so it can provide information about the chemical environment of a particular atom.
In the examples you provided, the first number after the chemical shift (δ) represents the position of the peak in ppm, followed by the number of hydrogens (H) contributing to the peak, the type of signal (s for singlet, d for doublet, t for triplet, dd for doublet of doublets, etc.), and any additional information such as coupling constants (J) or multiplicity (m). The letters in parentheses indicate the solvent used for the measurement.
As for the French example, it follows a similar notation, with the chemical shift (δ) expressed in a different format and the use of commas instead of parentheses. It also includes information about the peak shape (s for sharp, ls for broad), and the letters in parentheses indicate the type of experiment used (HPLC - High Performance Liquid Chromatography).
For a more detailed explanation of NMR spectra notation and nomenclature, I would recommend consulting a textbook or online resources such as the NMR Chemical Shifts Database. I hope this helps!
FAQ: Guide to NMR spectra notations/nomenclature needed
What is NMR spectroscopy?
NMR spectroscopy is a scientific technique used to analyze the structure and composition of molecules by measuring the interaction between the nuclei of atoms and an external magnetic field.
Why is nomenclature important in NMR spectroscopy?
Nomenclature in NMR spectroscopy helps to standardize the way we refer to different parts of a molecule's NMR spectrum. This allows for better communication and understanding among scientists.
What are the common notations used in NMR spectra?
The most common notations used in NMR spectra include chemical shift, integration, multiplicity, and coupling constant.
How is chemical shift represented in NMR spectra?
Chemical shift is represented by a number in parts per million (ppm) and indicates the position of a peak in the NMR spectrum relative to a reference compound.
What does multiplicity tell us in NMR spectra?
Multiplicity refers to the number of peaks in a given peak, which can provide information about the number of neighboring hydrogen atoms in a molecule and their relative positions.
