Guitar effect introduces noise if I'm not touching it's metal case. Why?
In summary, the individual is experiencing white noise when using their homemade guitar effect, which goes away when they touch the case. They have discovered that the noise also disappears when they hold the input sockets, and they are seeking help on how to fix this issue. They are advised to check that the case is properly connected to ground, and to make sure they are not using insulation jack. They are also advised to use an ohmmeter to check for any open connections between the guitar strings, case, and input jack. The individual also clarifies that the noise is white noise, not the 60Hz hum commonly associated with electrical issues.
btmm
As the title says, a guitar effect I built introduces a lot of white noise, which goes away when I touch it's case.
I removed the circuit from the case and found the noise also goes away when I hold the input sockets. How do I fix this?
Thanks for any help!
You need to check that the case (metal presumably) is connected to earth/ground by means of the outer casing of the lead to the guitar.
I have built and repaired lots of electric guitars and this is the most common electrical effect. You probably realize that all of the exposed metalwork (bridge, socket, switch/ control plate etc) are all connected together and then connected to earth/ground
Do you mean this is a battery operating stomp box like a Fuzz Face etc. that don't have power plug that plug into the wall. Guitar just plug into the effect box and a coax jack from the effect box plug into the amplifier? How about when you just hold the guitar by the neck where you touch the strings while plug into the effect box? The strings are usually connect to the ground where it plug into the effect box. Make sure you are not using insulation jack.
Do you have a ohmmeter? If so, measure the string of the guitar to the case of the box. Also from the case of the box to the outside of the input jack of the amplifier. They should be shorted as these are all supposed to be grounded. If you find one is open, that's where your problem is.
What do you mean by white noise, usually problem like this is the 60Hz and it's harmonics, not white noise. White noise is wide band hissing sound...like Pzzzzzzz......
FAQ: Guitar effect introduces noise if I'm not touching it's metal case. Why?
Why does my guitar effect introduce noise when I'm not touching its metal case?
The metal case of a guitar effect pedal acts as a shield or barrier to electromagnetic interference (EMI) that is present in the environment. When you touch the metal case, your body acts as a ground and helps to dissipate the interference. However, when you are not touching the metal case, the EMI can enter the circuit and cause unwanted noise.
Is this a common issue with all guitar effects?
Yes, this is a common issue with most guitar effects, especially those that are housed in metal cases. However, some manufacturers have designed their pedals with internal shielding to reduce the impact of EMI, so it may vary from pedal to pedal.
Can this issue be fixed?
Yes, there are a few solutions to reduce the noise caused by not touching the metal case of a guitar effect. One option is to use a noise gate pedal to suppress the unwanted noise. Another option is to use a power supply with built-in isolation, which can help reduce the impact of EMI. Additionally, using shielded cables and keeping your guitar effect away from other electronic devices can also help.
Is there anything I can do while playing to reduce the noise?
Yes, there are a few techniques that can help reduce the noise caused by not touching the metal case of a guitar effect. One is to use a noise gate pedal, as mentioned before. Another is to physically touch the metal case of the pedal or your guitar strings while playing, as this can act as a ground and help dissipate the interference.
Can this issue affect the sound quality of my guitar effect?
Yes, the noise caused by not touching the metal case of a guitar effect can affect the sound quality. It can create unwanted buzzing or humming sounds that can be distracting and affect the overall tone and clarity of your guitar. That's why it's important to address this issue and find solutions to reduce the noise.
