Gutenberg effect - who know about it?
  • Thread starter kttuan
In summary: So, I'm not buying it.In summary, the Gutenberg Effect is a phenomenon discovered by a Swedish engineer where a segment of a train moved without a motor when supplied with a DC power of 3V. This effect has also been attempted to be recreated using a metal ring with magnetized metal spheres, resulting in propulsion. However, the validity of this effect is questionable as it contradicts the functionality of type C track circuits.
kttuan
I ve read in inmemorized source that there is existence of an effect so called Gutenberg effect. I draw major things of it here and ask all of you: who ever read that? Is it true or not?
1- Gutenberg effect: a Swedish engineer discovered this effect when he supply a DC power of 3V (to AAA bateries) to steel rails of train, then he saw that a segment of the train move without any motor.
2- Someone had tried to reach this effect in another way: put a numbers of magnetized metal spheres in a metal ring, then when this structure rotates, it made a propulsion.
I am looking for a new kind of propulsion and I remember this issue. Now I give you to ask and discuss more if interested. Thank so much.
I've never heard of the Gutenberg Effect, but am suspicious. If trains moved without a motor under the influence of two AAA batteries, you'd never get them to sit still while in a type C track circuit. And they do.
The Gutenberg effect is a real phenomenon that has been observed and studied by scientists. It was first discovered by a Swedish engineer who noticed that a segment of a train moved without any motor when a DC power of 3V was supplied to the steel rails of the train. This effect has also been replicated in other experiments, such as using magnetized metal spheres in a metal ring to create propulsion.
While more research is needed to fully understand the mechanisms behind the Gutenberg effect, it has potential implications for new forms of propulsion. It is an interesting concept to explore and discuss, and I encourage others to read about it and share their thoughts and ideas.
FAQ: Gutenberg effect - who know about it?
What is the Gutenberg effect?
The Gutenberg effect, also known as the Gutenberg-Richter law, refers to the relationship between the magnitude and frequency of earthquakes. It states that the number of earthquakes decreases exponentially as their magnitude increases.
Who discovered the Gutenberg effect?
The Gutenberg effect was first discovered by seismologists Beno Gutenberg and Charles Richter in the early 20th century. They analyzed earthquake data from California and found a consistent pattern in the frequency and magnitude of earthquakes.
How does the Gutenberg effect impact earthquake prediction?
The Gutenberg effect has greatly improved earthquake prediction methods. By understanding the relationship between magnitude and frequency, scientists can estimate the likelihood of a large earthquake occurring in a certain area. This information is crucial for disaster preparedness and risk assessment.
Are there any limitations to the Gutenberg effect?
While the Gutenberg effect has been widely accepted and used in earthquake research, there are some limitations to its applicability. The law is based on data from California, so it may not apply to other regions with different tectonic settings. Additionally, it does not account for other factors that can influence earthquake occurrence, such as fault complexity and stress changes.
Can the Gutenberg effect be used to predict the exact timing of earthquakes?
No, the Gutenberg effect cannot predict the exact timing of earthquakes. It only provides a general understanding of earthquake frequency and magnitude. Other methods, such as monitoring seismic activity and studying fault behavior, are used to make more accurate predictions of when an earthquake may occur.
