MHB GWR309's question at Yahoo Answers regarding Lagrange multipliers
The discussion focuses on using Lagrange multipliers to optimize the function f(x,y) = xy under the constraint g(x,y) = x - 2y - 1 = 0. The critical point is found to be (x,y) = (1/2, -1/4), yielding a minimum value of f(1/2, -1/4) = -1/8. The method involves setting up a system of equations derived from the partial derivatives of the objective and constraint functions. To determine whether the critical point is a maximum, minimum, or neither, one can check the Hessian matrix or evaluate the function at other test points. This approach provides a systematic way to find extrema in constrained optimization problems.
MarkFL
MHB
Here is the question:
Please help with lagrange multipliers?
I don't understand how to do these at all. Here is one of the problems I have to do:
f(x,y) = xy x-2y=1Additional Details i thought I had more spaces when I typed... xy and x-2y=1 are 2 different equations.
Here is a link to the question:
Please help with lagrange multipliers? - Yahoo! Answers
I have posted a link there to this topic so the OP can find my response.
Mathematics news on Phys.org
Hello GWR309,
We are given the objective function:
$$f(x,y)=xy$$
subject to the constraint:
$$g(x,y)=x-2y-1=0$$
Using Lagrange multipliers, we get the system:
$$y=\lambda$$
$$x=-2\lambda$$
and this implies:
$$x=-2y$$
Substituting for $x$ into the constraint, we find:
$$-2y-2y-1=0$$
$$y=-\frac{1}{4}\,\therefore\,x=\frac{1}{2}$$
And so the critical point is:
$$(x,y)=\left(\frac{1}{2},-\frac{1}{4} \right)$$
and the optimize value for the objective function is:
$$f\left(\frac{1}{2},-\frac{1}{4} \right)=-\frac{1}{8}$$
Since other test points such as $$\left(0,-\frac{1}{2} \right)$$ and $$\left(1,0 \right)$$ give $$f(x,y)>-\frac{1}{8}$$ we may conclude that:
$$f_{\min}=f\left(\frac{1}{2},-\frac{1}{4} \right)=-\frac{1}{8}$$
As a check, we may use the constraint to write $f$ as a function of 1 variable, namely:
$$f(x)=\frac{x}{2}(x-1)$$
We can see now that $f(x)$ is a parabola opening upwards, and we know its vertex (which is the global minimum) will line on the axis of symmetry, which is midway between the roots, on the line:
$$x=\frac{1}{2}$$
and so the minimum is:
$$f_{\min}=f\left(\frac{1}{2} \right)=-\frac{1}{8}$$
To GWR309 and any other guests viewing this topic, I invite and encourage you to post other optimization problems in our http://www.mathhelpboards.com/f10/ forum.
Best Regards,
Mark.
MarkFL said:
Hello GWR309,
$$f(x,y)=xy$$
$$g(x,y)=x-2y-1=0$$
$$y=\lambda$$
$$x=-2\lambda$$
and this implies:
$$x=-2y$$
$$-2y-2y-1=0$$
$$x=\frac{1}{2}$$
Best Regards,
Mark.
Where did you get the system though? this:
y=λ
x=−2λ
y=λ
x=−2λ
Hello GWR309,
Glad you joined us here! (Cool)
The method of Lagrange multipliers states:
To find the extrema of $z=f(x,y)$ subject to the constraint $g(x,y)=0$, solve the system of equations:
$$f_x(x,y)=\lambda g_x(x,y)$$
$$f_y(x,y)=\lambda g_y(x,y)$$
$$g(x,y)=0$$
Among the solutions $(x,y,\lambda)$ of the system will be the points $$\left(x_i,y_i \right)$$, where $f$ has an extremum. When $f$ has a maximum (or minimum), it will be the largest (or smallest) number in the list of functional values $$f\left(x_i,y_i \right)$$.
So, given that:
$$f(x,y)=xy$$
$$g(x,y)=x-2y-1=0$$
we then find by computing the first partials, that:
$$f_x(x,y)=y,\,f_y(x,y)=x,\,g_x(x,y)=1,\,g_y(x,y)=-2$$
and so the system we are to solve is:
$$y=\lambda$$
$$x=-2\lambda$$
$$g(x,y)=x-2y-1=0$$
From the first two equations, we find:
$$\lambda=y=-\frac{x}{2}\,\therefore\,x=-2y$$
and the rest follows as in my second post above.
for general lagrange multipliers problems, how do I determine if it is a max, min or neither?
You could check the Hessian matrix. Or check that your function is convex (which would imply you have a minimum). Or even just substitute in the value and compare it to the endpoints of your function...
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
