H-Theorem and Lagrange multipliers
In summary: I am so sorry again, when you mean Galilei boost, where exactly am I supposed to apply galilean transformation? I am really sorry If I come accross as a bit naiveIn summary, the conversation discusses the derivation of the Sackur-Tetrode formula for entropy in an ideal gas using the H-theorem. The formula is derived by defining the entropy relative to "full information" and making the argument of the natural logarithm dimensionless. The discussion also mentions the use of Galilei boosts to obtain the coefficients for the distribution function in a moving frame. The conversation ends with a clarification on the relation between temperature and the total energy in the rest frame of the medium.
VVS2000
150
so I was studying H theorem from Richard Fitzpartic's site.
https://farside.ph.utexas.edu/teaching/plasma/Plasma/node35.html
Given H,
they consider the following equation
and set the constants as
I want to understand how they got these particular values for a, b &c
can we consider the following as constraints and a b c as lagrange multipliers and solve for them?
or if there are any other ways to obtain a b c plz do tell
thanks in advance
It's obviously for an ideal gas, for which we know the phase-space-distribution function exactly (let's take a monatomic gas for simplicity):
$$f=\frac{1}{(2 \pi \hbar)^3} \exp[-(\vec{p}^2-\mu)/(2m kT)].$$
Now comes the subtle point! To define the entropy (or the neg-entropy) you need to define it relative to "full information", and you have to make the argument of the ln dimensionless. What is "full information"? According to quantum theory it's that the phase-space volume the particle is contained in is determined by the uncertainty relation of position and momentum, i.e., in a volume of ##(2 \pi \hbar)^3##. So the entropy is
$$S=-H=-V \int \mathrm{d}^3 p f(p) [\ln[f/(2 \pi \hbar)^3]-1]-V k \int_{\mathbb{R}^3} \frac{1}{(2 \pi \hbar)^3} \exp[-(\vec{p}^2-\mu)/(2m kT)] \frac{\vec{p}^2-\mu}{2m k T}=n V \left (\frac{3 k}{2}-\frac{\mu}{T} \right)$$
with
$$n=\frac{N}{V}=\int_{\mathbb{R}^3} \mathrm{d}^3 p f(\vec{p})=(\frac{V (k m T)^{3/2}}{2 \sqrt{2 \pi^3} \hbar^3} \exp[\mu/(k T)].$$
Using this to eliminate ##\mu/T## in the formula for ##S##, leads to
$$S=n V \left [\frac{5 k}{2} - k \ln \left (\frac{2 \sqrt{2 \pi^3 n} \hbar^3}{(m k T)^{3/2}} \right ) \right],$$
which is the Sackur-Tetrode formula,
https://en.wikipedia.org/wiki/Sackur–Tetrode_equation
as can be derived by using ##U=3 N k T/2=3 n V kT/2##.
Likes dextercioby and VVS2000
with
OK I get what you're trying to say but I am not seeing how this is related to my question
After correcting the formula for ##H=-S## you get what I wrote. Now you can Galilei-boost this to an arbitrary inertial frame, where the gas moves with a velocity ##\vec{V}## to get the coefficients you look for.
I am just not able to see it
The Galilei boost for ##V## obviously is ##V'=V## and ##\vec{p}'=\vec{p}-m\vec{v}##. From this you get
$$f(\vec{p})=f(\vec{p}'+m \vec{v}).$$
Use this in the formula for ##S##. You don't need to calculate more integrals, because they are all calculated for ##\vec{v}=0##.
Likes VVS2000
After some PM discussion, I think, I misunderstood the question. Of course, it's also clear that ##S## is a Galilei invariant. So here's my answer to what I believe is the original question:
Obviously I misunderstood your question. Your idea in #1 is correct. The distribution function derived from the H-theorem is that of local thermal equilibrium. It's the distribution function for an ideal gas with center-of-mass velocity ##\vec{v}##, which you get from the standard Boltzmann distribution by a Galilei boost. For the gas at rest it's
$$f'(\vec{p}')=\frac{1}{(2 \pi \hbar)^3} \exp \left [-\frac{1}{kT} \left (\frac{\vec{p}^{\prime 2}}{2m}-\mu \right )\right].$$
In the frame, where the gas moves with velocity ##\vec{v}## you have
$$\vec{p}=\vec{p}'+m \vec{v}.$$
The distribution function is a scalar under Galilei boosts, i.e., you have
$$f(\vec{p})=f'(\vec{p}')=f'(\vec{p}-m \vec{v})= \frac{1}{(2 \pi \hbar)^3} \exp \left [-\frac{1}{kT} \left (\frac{(\vec{p}-m\vec{v})^2}{2m}-\mu \right )\right].$$
It's easy to calculate the expectation values for the total particle number, the total momentum, and the total energy in this frame, and this gives you indeed the Lagrange parameters ##a_i##, ##\vec{b}##, and ##c##.
For the latter, note that temperature is related to the total energy in the (local) rest frame of the medium, i.e., to
$$E'=V \int_{\mathbb{R}^3} \mathrm{d^3 p} \frac{\vec{p}^{\prime 2}}{2m} f'(\vec{p}')=\frac{3}{2} N k T,$$
where the particle number is given by
$$N=V \int_{\mathbb{R}^3} \mathrm{d^3 p'} f'(\vec{p}')=V \int_{\mathbb{R}^3} \mathrm{d^3 p} f(\vec{p}) = \left (\frac{mkT}{2} \right)^{3/2} \frac{V}{\hbar^3} \exp \left (\frac{\mu}{kT} \right)=nV.$$
For the total momentum you get
$$\vec{P}=V \int_{\mathbb{R}^3} \mathrm{d}^3 p \vec{p} f(\vec{p}) = V \int_{\mathbb{R}^3} \mathrm{d}^3 p' (\vec{p}'+m \vec{v}) f'(\vec{p}') = N m \vec{v},$$
where I've used that in the rest frame the total momentum vanishes.
Likes VVS2000
The distribution function ##f_i## is assumed to be of the form $$\ln f_i = a_i + m_i \mathbf{b}\cdot \mathbf{v}_i + m_i c v_i^2$$ where ##a_i, \mathbf{b},## and ##c## are constants.
Then the constants ##n_i, \mathbf{V},## and ##T## are defined in the link in terms of the constants ##a_i, \mathbf{b},## and ##c## by the equations
$$\begin{align*}
a_i & = \ln\left[n_i \left(\frac{m_i}{2 \pi T}\right)^{3/2}\right] - \frac{m_i V^2}{2T} \\
b & = \frac{1}{T}\mathbf{V}\\
c & = -\frac{1}{2T}
\end{align*}$$ At this point, the physical meaning of the constants ##n_i, \mathbf{V},## and ##T## is not evident.
You can then show that the distribution function in terms of these constants takes the Maxwell-Boltzmann form $$f_i = n_i \left(\frac{m_i}{2 \pi T} \right)^{3/2} \exp\left[- \frac{m_i(\mathbf{v}_i - \mathbf{V})^2}{2T} \right]$$
Using this form of ##f_i##, you find by straightforward integration that
$$\begin{align*}
n_i & = \int f_i \, d^3\mathbf{v}_i \\
n_i \mathbf{V} & = \int \mathbf{v}_i \, f_i \, d^3\mathbf{v}_i\\
\frac 3 2 n_i T & = \int \frac 1 2 m_i \, v_i^2 \, f_i \, d^3\mathbf{v}_i - n_i \frac 1 2 m_i V^2
\end{align*}$$
Note that the last equation here differs from equation (3.55) in the link where the last term is not included. I believe (3.55) in the link is incorrect.
These equations show the physical meaning of the constants ##n_i, \mathbf{V}, ## and ##T##.
Of course, the student could be left scratching her head wondering how anyone would know ahead of time to define the constant ##n_i## by the strange-looking equation ##a_i = \ln\left[n_i \left(\frac{m_i}{2 \pi T}\right)^{3/2}\right] - \frac{m_i V^2}{2T}##.
Another way to develop this is to define the constants ##n_i, \mathbf{V},## and ##T## by the physically meaningful equations
$$\begin{align*}
\frac 3 2 n_i T & = \int \frac 1 2 m_i \, v^2 \, f_i \, d^3\mathbf{v}_i - n_i \frac 1 2 m_i V^2
\end{align*}$$ where ##f_i## is the distribution function defined in terms of the constants ##a_i, \mathbf{b},## and ##c## : $$\ln f_i = a_i + m_i \mathbf{b}\cdot \mathbf{v}_i + m_i c v_i^2$$ That is, $$f_i = \exp[ a_i + m_i \mathbf{b}\cdot \mathbf{v}_i + m_i c v_i^2]. $$ Then you can derive the equations
$$\begin{align*}
c & = -\frac{1}{2T}
\end{align*}$$ by carrying out the integrations in
$$\begin{align*}
\end{align*}$$
For example, with ##f_i = \exp[ a_i + m_i \mathbf{b}\cdot \mathbf{v}_i + m_i c v_i^2] ##, you can show that $$\begin{align*}
\int f_i \, d^3 \mathbf{v}_i & = \left(\frac{\pi}{m_i|c|} \right)^{3/2} \exp\left[ a_i + \frac{m_ib^2}{4|c|} \right] \\
\int \mathbf{v}_i \, f_i \, d^3 \mathbf{v}_i & = n_i \frac{\mathbf{b}}{2|c|} \\
\int v_i^2 \, f_i \, d^3 \mathbf{v}_i & = n_i \left( \frac{3}{2 m_i |c|} + \frac{b^2}{4c^2} \right)
\end{align*}$$ Using these in the defining relations
$$\begin{align*}
\end{align*}$$ gives three equations that can be used to derive
$$\begin{align*}
c & = -\frac{1}{2T}
\end{align*}$$
This approach is fairly tedious. But it has the advantage of not having to pull the equation ##a_i = \ln\left[n_i \left(\frac{m_i}{2 \pi T}\right)^{3/2}\right] - \frac{m_i V^2}{2T}## out of thin air.
Likes vanhees71, VVS2000 and dextercioby
FAQ: H-Theorem and Lagrange multipliers
What is the H-Theorem?
The H-Theorem, formulated by Ludwig Boltzmann, states that the entropy of an isolated system will never decrease over time, leading to the second law of thermodynamics. It provides a statistical basis for the irreversibility of macroscopic processes by showing that the distribution of particles in a gas will evolve towards a state of maximum entropy, or thermodynamic equilibrium.
How does the H-Theorem relate to entropy?
The H-Theorem is fundamentally linked to the concept of entropy. It demonstrates that the entropy of an isolated system, defined by Boltzmann's H-function, will always increase or remain constant over time. This increase in entropy corresponds to the system's evolution towards a more disordered state, in line with the second law of thermodynamics.
What are Lagrange multipliers?
Lagrange multipliers are a mathematical tool used in optimization problems to find the local maxima and minima of a function subject to equality constraints. By introducing additional variables (the multipliers), the method transforms the constrained problem into an unconstrained one, which can then be solved using standard techniques.
How are Lagrange multipliers used in the context of the H-Theorem?
In the context of the H-Theorem, Lagrange multipliers are employed to enforce the conservation laws (such as energy, momentum, and particle number) when finding the equilibrium distribution of particles in a system. By applying the method of Lagrange multipliers, one can derive the Maxwell-Boltzmann distribution, which describes the most probable distribution of particle velocities in a gas at equilibrium.
Can you provide an example of using Lagrange multipliers in statistical mechanics?
Sure. Consider a system of particles where we want to maximize the entropy subject to constraints on the total number of particles and the total energy. The entropy function S can be maximized using Lagrange multipliers by introducing multipliers for the constraints. Solving the resulting equations gives us the Maxwell-Boltzmann distribution, which describes the equilibrium state of the system. This process involves setting up and solving the equations derived from the partial derivatives of the Lagrangian, which includes the original function and the constraints multiplied by their respective Lagrange multipliers.
