What is the preheat temperature for the water entering the gas boiler?
In summary, the calculations for the preheat temperature of the water leaving the heat exchanger are difficult to perform and require information about the temperatures of the water entering and leaving the heat exchanger.
Seta
Summary:: I need to know the preheat temperature of the water entering the gas boiler (which i think is the outlet temperature of the cold water Tc,o leaving the heat exchanger)
Hi, I'm doing a design project of a hairpin heat exchanger. The problem is:
In a public shower, the city water is heated in a gas boiler from 15 °C to 43 °C at an average flow rate of 2 kg/s. In an attempt to save energy consumption, it is proposed to collect the lukewarm water drained at the temperature of 38 ° C and pass it through a heat exchanger to preheat the incoming cold water (which is at 15 °C). If the dimensions of the space in which the heat exchanger will be installed are 1m x 3m x 1m, design a hairpin-type heat exchanger which must properly perform this task.
From here, i have to do a schematic diagram of the water circuit with different devices (position of the HX, pumps, valves, boiler,...), and do the different calculations.
My problem is, i couldn't calculate the preheat temperature of the water leaving the HX.
I've done the schematic diagram, is this the right way to do it, and should i add or remove something from it ?
Hello @Seta , :welcome: !
Did you read the guidelines ? We are not allowed to help if you don't post your own attempt at solution.
Also, it would help if you provide some context and information to help us assist you at the proper level: what do you know about HX design , do you have access to the VDI Heat Atlas, ever seen Q = UA*LMTD etc. And who made the choice of a hairpin-type instead of a plate HX -- teacher ?
Likes Lnewqban
Sorry, it's my first time using this forum.
What i want to do is to find the number of hairpins needed with : Q = UA_hp *LMTD*N_hp where A_hp is the area of the inner tube of one hairpin HX, and N_hp is the number of hairpins.
The problem here is that to find Q i have to know either the outlet temperature of the lukewarmed water Th,o or the preheated water Tc,o with : Q = m_c * Cp_c * ( Tc,o - Tc,i ) = m_h * Cp_h * ( Th,i - Th,o ).
Same thing goes for LMTD.
Then I'll calculate U by calculating the sum of the resistances, and to do so I'll have to find the convection coefficients inside the tube and in the annulus by calculating the reynolds number, nusselt number ...
The main problem here is the lack of information about the temperatures, that's what kept me stuck.
And yes, the teacher decided to use a hairpin type HX.
Thank you.
Good info!
The usual path in designing such a contraption is that you make a starting guess of U and if necessary refine in subsequent iterations. From Coulson and Richardson Vol 6: water/water shell and tube: 800-1500 W/(m2 ##\cdot## K). Or here 150-1200. So perhaps try 1000. (low flow water at low P allows thin pipes).
You have approximately equal flowrates, so with an infinitely large exchanger you can preheat to the 38 ##^\circ##C (if you believe that number) and cool down to 15. The limit is size and in 3 m3 you can stuff a huge area of pipe. The tradeoff is investment versus efficiency: adding area doesn't give a good return on investment after a while.
Do the calculations with an equation solver (see engineeringtoolbox), or better: iterate in excel for good understanding or use the ##\varepsilon-##NTU method.
Check how sensitive (or rather insensitive) heat recovery percentage is under changes in UA once you are in the range 80-90%.
Allow some fouling and there you are !
Nice exercise; let us know how it goes :smile:
Likes berkeman
From what i understand, i have to take Th,o = 15 °C and Tc,o = 38 °C , but if i do so, which value should i take for LMTD since ( Th,i - Tc,o ) = ( Th,o - Tc,i ) = 0 ?
On the other hand, when i asked my teacher about the preaheat temperature Tc,o , he said that it has to be calculated.
That's with an infinitely big HX. No wonder LMTD breaks down !
So take e.g. 90% recovery: LMTD still breaks down but we know that in the limit ##\Delta T_A \rightarrow \Delta T_B## the LMTD goes like ##LMTD \rightarrow \Delta T_A## (don't we ? :smile: )
Sure. It follows from Q = UA LMTD
Alright, thank you so much !
Likes berkeman
Sheer curiosity: how is it going ? I scribbled a few calculations and can imagine this is a meaningful and challenging exercise !
Also raises a few questions: the schematic suggests a single-shower application, but the 3 m3 seems a bit hefty for that ?
With 10 l/min and 23 ##^\circ##C ##\Delta##T, a maximum of 16 kW can be recovered, but then there is no ##\Delta##T left over (I think the professinals call that the 'approach').
If we aim for 80% that leaves ##\Delta##T = 4.6 ##^\circ##C meaning we need a UA of 3.5 kW/##^\circ##C
It can be done. Compare notes ?
Yes that's true, this isn't for one shower only, i should've added more.
Honestly, i am a little bit lost, i started calculations with 80% recovery :
q = 0.8 * 2 * 4.1786 * (43 - 15) = 187.2 kW // I took Cp_c at T = (43+15)/2 = 29 °C
Now i'll start to work with NTU-eps method:
q_max = m_c * Cp_c * (Th,i - Tc,i) = 192.234 kW // i took Cp_c at T = (38+15)/2 = 26.5 °C
==> eps = q / q_max
==> NTU = eps / (1-eps) // I took the heat capacity ratio equals 1 because the flowrates and the specific heat capacities are aproximately the same.
==> Uo * A_hp * N_hp = Cmin * NTU = m_c * Cp_c * NTU
And now, by first guessing Uo i can find the proper geometry, or i choose the dimensions first, then i'll calculate Uo.
I don't know if this the right way to do it, but i strongly doubt the results.
I don't see the 43##^\circ## anywhere near the heat exchanger ?
Other than that:
I suppose you want to run 12 showers simultaneously ?
Why ? Not sure I follow this NTU method -- maybe more ime tomoow.
I agree.
A_hp ? N_hp ?
Likes Seta
Had to rehash my NTU stuff (almost never use it):
Seta said:
q = 0.8 * 2 * 4.1786 * (43 - 15) = 187.2 kW // I took Cp_c at T = (43+15)/2 = 29 °C ##\qquad## (1)
q_max = m_c * Cp_c * (Th,i - Tc,i) = 192.234 kW // i took Cp_c at T = (38+15)/2 = 26.5 °C ##\qquad## (2)
==> eps = q / q_max##\qquad## ##\qquad## ##\qquad## (3)
==> NTU = eps / (1-eps) // I took the heat capacity ratio equals 1 because the flowrates and the specific heat capacities are aproximately the same. ##\qquad## (4)
==> Uo * A_hp * N_hp = Cmin * NTU = m_c * Cp_c * NTU ##\qquad## (5)
ad 1:
The HX sees one input at 38, the other at 15 C. The 43 C is elsewhere, so it can't appear here​
I suppose the 0.8 is ##\varepsilon##​
I suppose the 2 is mass flow, 2 m3/s = 120 L/min, so 12 showers​
ad 2: I agree (but 3 digits is sufficient accuracy here ...)
ad 3:
No, ##q =\varepsilon\,q_{\,\text{max}}\ ##, so some 154 kW !
ad 4: Fully agree
ad 5:
I guess A_hp is a hairpin area and N_hp is their number :rolleyes:
You have an initial guess for U. That gives you an area.
Pick a pipe diameter ##\Rightarrow## number of pipes. A check on the 3 m3.
Flow speed in the pipes, pressure drop, pipe wall thickness etc.
Then you might look at U again
good luck!
Likes Seta
FAQ: What is the preheat temperature for the water entering the gas boiler?
1. What is a hairpin heat exchanger?
A hairpin heat exchanger is a type of heat exchanger that consists of a U-shaped tube that is bent into a hairpin shape. The fluid flows through one side of the hairpin and then reverses direction to flow through the other side, allowing for efficient heat transfer.
2. How does a hairpin heat exchanger work?
A hairpin heat exchanger works by using the hairpin design to create a counterflow or parallel flow configuration, depending on how the tube is bent. This allows for the two fluids to come into close contact and transfer heat from one to the other.
3. What are the advantages of using a hairpin heat exchanger?
One advantage of using a hairpin heat exchanger is its compact size, making it suitable for use in small spaces. It also has a high heat transfer coefficient, meaning it can transfer heat quickly and efficiently. Additionally, the hairpin design allows for easy cleaning and maintenance.
4. What factors should be considered when designing a hairpin heat exchanger?
When designing a hairpin heat exchanger, factors such as the flow rate, temperature, and pressure of the fluids, as well as the material of the tubes, should be considered. The length and diameter of the hairpin also play a role in determining the heat transfer efficiency.
5. How can the performance of a hairpin heat exchanger be improved?
The performance of a hairpin heat exchanger can be improved by increasing the surface area of the tubes, using materials with high thermal conductivity, and optimizing the flow pattern to maximize heat transfer. Regular maintenance and cleaning can also help improve the efficiency of the heat exchanger.
11K
